Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > How much alternator power is needed?
Author Thread: How much alternator power is needed?
Username: Lexdiamond
I have two amplifiers, an Alpine PDX-2.150 and an Alpine PDX-1.1000 (1300 RMS @ 14.4v) and a 160 watt DC-DC power supply running a computer with many peripherals.
What do i need for alternator power or battery(I have a yellow top)
How do I get the battery to put out 14.4v instead of 12v?
Username: N2audio
Lawrence, Ks
Post Number: 1298
batteries don't put out 14.4 - they put out 12.6 -- beyond that it's up to the alternator.
As for alt size -- in an average car I would think 150A would be plenty.
If you don't have extreme listening habits a common 110-130A stock alt would likely do the job.
Username: Oleg
Santa Monica, CA
Post Number: 1342
Dang computer w/ peripherals in the car? Talking about being on the go
Username: Nd4spd18
Southeast PA
Post Number: 2273
X2 to what Optidriven said...... I would use at least a 150-160 amp alt
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > How much alternator power is needed? [ « Previous ] [ Next » ]
