Thread: A/D/S/ 346CS help |
Silver Member Username: Kklagge
San Diego
Post Number: 453 Registered: Dec-04
| Posted on Wednesday, May 09, 2007 - 03:27 pm: |
I'm wondering how owners of these comps have them wired up? Are you running them as you would a normal set of comps through the xover, or are you bi-amping them through the xover? If you are bi-amping them what kind of wattages are you giving the mid & tweet? I have a 4-channel Kicker (birth sheet says it will do 400rms) and was thinking of bi-amping these comps with 100rms to the mid & 50rms to the tweet (with the high pass on the HU set at 80hz). Would like a little feedback on owners of these as to what you've found out in any experimentation you may have done. Thanks |
Bronze Member Username: Sqhoe
Huntington,
IN
Post Number: 11 Registered: Mar-07
| Posted on Thursday, May 10, 2007 - 07:48 am: |
I have them running throught the crossovers with 120rms crossed at 70hz. I think they sound great. Be sure to deaden the doors and you will be happy with the midbass from these things! |
San Diego
Post Number: 454 Registered: Dec-04
| Posted on Thursday, May 10, 2007 - 08:14 am: |
Do you have them bi-amped through the xovers? Or did they use to come with a different set of xovers? The set I just purchased has the ability to run them as a normal set of comps or also bi-amp them through the same xover. |
Huntington,
IN
Post Number: 12 Registered: Mar-07
| Posted on Thursday, May 10, 2007 - 01:42 pm: |
No, I have them run with one input and letting the crossover split it up. Thought about bi-amping, but my amp only does 40x4 so I bridged it to 2 channel. |
San Diego
Post Number: 455 Registered: Dec-04
| Posted on Thursday, May 10, 2007 - 01:57 pm: |
Alright...thanks for the input...I may just hook them up like normal for the ease of it...my amp puts out 170x2 bridges so I have plenty of power. How are the tweets? I've heard that they sound very natural. I currently have a set of CDT CL-62's in the doors but am looking for something that will handle a little more power...and maybe give out some better midbass |
Bronze Member Username: Gfbl
Post Number: 65 Registered: Oct-06
| Posted on Thursday, May 17, 2007 - 08:21 am: |
biamped through the cross with 75watts to speakers and tweets. they sound great |
