Thread: 1/0 to dist block... |
Silver Member Username: Skies
Courtenay,
British Colu...
Post Number: 680 Registered: Aug-05
| Posted on Wednesday, May 09, 2007 - 02:15 am: |
If I've got a sub amp and a speaker amp, some 1/0 wiring kickin around, not enough for 2 full runs for each amp, could I not just use 1/0 up to a distribution block, then 1/0 to each amp from the dist block? Might seem like a stupid question but anyways, thanks for you time. |
Gold Member Username: Johnfiac
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2688 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 04:01 am: |
Depends on how much power your trying to pull, and the wires coming from the dist. block have to be big enough still. If its under 2K you shouldnt have a problem. |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 2465 Registered: Jul-06
| Posted on Wednesday, May 09, 2007 - 11:50 am: |
That would work out fine Skies.You may need to step the wire size down though using a 1/0 to dual 4Awg or distro block or something like that for your speaker amp. |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1343 Registered: Nov-04
| Posted on Thursday, May 10, 2007 - 12:18 am: |
Yeah, you can use a fused distribution block and do 2 very short runs of 4awg wire from there. |
Courtenay,
British Colu...
Post Number: 691 Registered: Aug-05
| Posted on Thursday, May 10, 2007 - 12:46 am: |
That's the thing though, I don't have any 4awg wire sitting around, would I just be able to use some 1/0 that I have sitting around to save some funds? |
Santa Monica,
CA
Post Number: 1347 Registered: Nov-04
| Posted on Thursday, May 10, 2007 - 12:56 am: |
Do you already have the block? Most distribution blocks output smaller wire than they accept. |
Santa Monica,
CA
Post Number: 1348 Registered: Nov-04
| Posted on Thursday, May 10, 2007 - 01:02 am: |
You'll need one like this: http://cgi.ebay.com/DB-Link-Chrome-0-Gauge-T-Distribution-Block-AWG-GA_W0QQitemZ 170109379998QQihZ007QQcategoryZ50550QQrdZ1QQcmdZViewItem 0awg in and 0awg out. |
Post Number:...
Post Number: 2487 Registered: Jul-06
| Posted on Thursday, May 10, 2007 - 11:26 am: |
"That's the thing though, I don't have any 4awg wire sitting around, would I just be able to use some 1/0 that I have sitting around to save some funds?" Sure,just strip the wire down to fit it inside the amp's terminals. |
Silver Member Username: Clouduz
Post Number: 204 Registered: Jun-06
| Posted on Thursday, May 10, 2007 - 04:11 pm: |
yes, that would work also |
