Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Test Tones used for setting component...
Author Thread: Test Tones used for setting component amp gain
Username: Bernymac
Cambodian
Post Number: 2634
What test tone should I use for setting a amp used for the midrange. 80hz-3.5khz? I'm guessing 80hz?
What test tone should I use for setting a amp used for the tweeters. 3.5khz and up?
I'm going to use a 50hz test tone to set my gain for my sub amp.
Username: Nd4spd18
Southeast PA
Post Number: 2223
80 is low..... I would use 100 if the amp is just for mids
Username: Bernymac
Cambodian
Post Number: 2635
amp is only for mids. What about the tweeter amp?
Username: Nd4spd18
Southeast PA
Post Number: 2224
Anything within the treble range..... 3.5 khz sounds good
Username: Johnfiac
A-ToWn, 152-153db Da...
My wangers b...
Post Number: 2724
i wish amps had a digital gain.. .where they set there self acording to what input voltage its getting.... now that would be a revolutionary change for amps.... i bet a ton of amps would live alot longer
Username: N2audio
Lawrence, Ks
Post Number: 1299
a lot of spkrs would live longer.
I don't think it would change amp survival much.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Test Tones used for setting component... [ « Previous ] [ Next » ]
