Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > The right amp for two 12" sd2.5's...
Author Thread: The right amp for two 12" sd2.5's
Username: Armstrong
Post Number: 8
hey, i just bought two 12" audioque sd2.5s which are dual 4 ohm subs and they are rated at 500 rms a piece. i plan on giving them anywhere from 600-800 rms a piece so a total of 1200-1600 rms is what i need. i believe i need an amp that is 1200-1600 at 1 ohm. my price range is about $275-300. could you guys please recommend me an efficient amp in my price range? thanks.
Username: Nyyfan13
Fi SSD
Post Number: 5024
mike loudons kicker kx1200.1 would work pretty nice...see if he still have it
http://forum.ecoustics.com/bbs/messages/4/352678.html
Username: Armstrong
Post Number: 9
that's a good deal, but i kinda wanted to buy new equipment.
Username: Imalik
SD2.5ED9.1=Boom, New Jersey
Audioque...N...
Post Number: 282
How much do want to spend...I have a ED nine.1 on my 2 SD 2.5
Username: Armstrong
Post Number: 10
i'm looking to spend about $275-300. a couple name brands i was looking at in my price range are power acoustik, planet audio, autotek, and hifonics.
Username: Oleg
Santa Monica, CA
Post Number: 1319
Here's a solid amp for you and should be just about in your budget:
http://cgi.ebay.com/NEW-ORION-HCCA-D2400-2400-WATT-CLASS-D-MONO-AMPLIFIER_W0QQit emZ180115160783QQihZ008QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Nd4spd18
Southeast PA
Post Number: 2216
That Orion is a good amp, you could also contact Kevin at low-hz about a Massive 1500.1, he has good prices on Massive amps.
Username: Oleg
Santa Monica, CA
Post Number: 1322
Dang those massive amps look goooood, I just checked them out on their homepage.
Username: Oleg
Santa Monica, CA
Post Number: 1323
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > The right amp for two 12" sd2.5's... [ « Previous ] [ Next » ]
