Thread: Alpine type r's..WHAT AMP?? |
New member Username: Mspatriot15
NE
Post Number: 2 Registered: May-07
| Posted on Tuesday, May 08, 2007 - 12:43 am: |
i just bought 2 SWR-1222D Alpine 12" Type-R.. i dont know n e thing bout this suff...i know eah of the subs are dual voice coil and 2 ohms.... 1500 peak power and 500 RMS each..i need to know how much watts..channels..etc. my amp needs to have to get the full 500 RMS outta each of the subs....im not lookin to spend over $200 for it maybe a little more..thanks everyone} |
Gold Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 1507 Registered: Oct-04
| Posted on Tuesday, May 08, 2007 - 09:33 am: |
http://cgi.ebay.com/AUDIOBAHN-A16000V-MONO-1600-WATT-AMPLIFIER-NEW-07-AMP_W0QQit emZ140112987545QQihZ004QQcategoryZ64570QQrdZ1QQcmdZViewItem http://cgi.ebay.com/MA-AUDIO-HK1998-MONOBLOCK-AMPLIFIER-1200W-MONO-AMP-NEW_W0QQi temZ300109082671QQihZ020QQcategoryZ64570QQrdZ1QQcmdZViewItem hard to find something for $200 |
Silver Member Username: Clouduz
Post Number: 200 Registered: Jun-06
| Posted on Tuesday, May 08, 2007 - 08:12 pm: |
I would suggest a hifonics 1606d i believe they are under $200 i think |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1317 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 09:35 pm: |
Here's your cheapest amp choice with a good quality amp: http://cgi.ebay.com/NEW-06-JBL-GTO1201-1-II-2-MONO-AMP-1200-WATT-PLEXI-TOP_W0QQi temZ290114291448QQihZ019QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem You'll need to have sub's coils wired in series and subs in parallel - if you're getting it professionally installed, be sure to tell the installer that...they may mess it up. The amp you get needs to be 2ohm stable. That JBL is probably your best bet. |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 2215 Registered: Jul-06
| Posted on Tuesday, May 08, 2007 - 09:55 pm: |
Definitely do not get an audiobahn or MA audio. Hifonics are ok, and that JBL would be good. |
Santa Monica,
CA
Post Number: 1320 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 10:04 pm: |
Ok we're not starting another "audiobahn" thread, but they're absolutely NOT a terrible brand and I'd never say "definitely do not get." I've had my amp for 4 years and it's awesome. Isaac has personally tested their intake series amp and said it's a great deal for the money...the amp puts out the power and is decent quality. Anyway, go with that JBL b/c the audiobahn one's not the right match for the setup. |
Santa Monica,
CA
Post Number: 1324 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 10:14 pm: |
Gold Member Username: Johnfiac
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2684 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 01:21 am: |
JBL Bp1200.1 used  |
Santa Monica,
CA
Post Number: 1327 Registered: Nov-04
| Posted on Wednesday, May 09, 2007 - 01:32 am: |
No real need to get that used one when the newer models are pretty fairly priced as is. |
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2685 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 01:45 am: |
I only suggest it because it is also 1 ohm stable, non like the new ones that arent(future upgrades are easier) it does like 1300-1400rms at 1 and 2 ohm... |
Santa Monica,
CA
Post Number: 1330 Registered: Nov-04
| Posted on Wednesday, May 09, 2007 - 01:55 am: |
I don't know about that amp being 1ohm stable... http://manuals.harman.com/JBL/CAR/Owner%27s%20Manual/bp_om.pdf There are new JBL models that are 2ohm stable and there're others that are 1ohm stable (i.e.: bpx1100.1 and bpx2200.1). |
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2686 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 02:29 am: |
the bp1200.1? It is |
Santa Monica,
CA
Post Number: 1333 Registered: Nov-04
| Posted on Wednesday, May 09, 2007 - 02:36 am: |
Where does it say this? |
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2687 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 03:56 am: |
look in the pdf you linked above.... it says lowest stable load 1 ohm* (* = gets the same power as 2ohm) look at the specs for the list of amps... looks like all the BP (mono blocks)series are 1ohm stable, 2 ohm optimized |
Santa Monica,
CA
Post Number: 1334 Registered: Nov-04
| Posted on Wednesday, May 09, 2007 - 04:01 am: |
I see...very interesting. |
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2693 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 04:12 am: |
bad@ss amp... for a used amp i dont think you can really beat it for 200$ if not cheaper... |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4575 Registered: Dec-05
| Posted on Wednesday, May 09, 2007 - 01:57 pm: |
^^^^x2 |
