Home > Message Board > Car Audio > Speakers > Archive through June 02, 2007 > Cdt hd-62/m6 going active frequency r...
Author Thread: Cdt hd-62/m6 going active frequency range?
Username: Bernymac
Cambodian
Post Number: 2604
I sent this to CDT. what do you guys think. and which range do you guys think I should use. I know its user preference but I'm not that experienced and would like to know which range will probaly sound the best while keeping up with my subwoofers.
Emailed to CDT:
I want to run this system active for better control. I need to know how much power the M6 and DRT25 tweeter can handle at the following ranges.
M6 @ 80hz-3khz -
M6 @ 80hz-300hz -
M6 @ 300hz-3khz -
M6 @ 300hz-3.5khz -
Drt25 @ 3khz and up -
Drt25 @ 3.5khz and up -
I need to know how much power I can send to the M6 and Tweeters at the following ranges. Thank you, any information will be helpful.
I have a massive audio p800.4 for the M6 Drivers. It does 160rms @ 12.4volts and 200rms @ 14.4 volts
I have a Xtant 404M for the drt25 tweeters which does 50rms x 4
Does anyone know if the m6's can handle up to 200rms if I high pass them at a higher range such as 300hz-3khz or 3.5khz.
Whats the difference if I high pass tweeters at 3khz or 3.5khz. Besides handling power, what would I notice in hearing. Will it sound less if I high pass it at 3khz? Will it be stronger if I high pass it at 3.5khz?
Just thought I would ask here before CDT gets a chance to respond.
Username: Adddisorder
West palm, Florida
Post Number: 4254
you cant run them at 300hz and up unless your running another midbass driver or unless you want to miss out on alot of music.
just run them 80-3k and 3kup on the tweets and just play around with all of the settings to see what you like.
Username: Bernymac
Cambodian
Post Number: 2621
I was going to buy a midbass driver to play the 80hz - 300hz range.
West palm, Florida
Post Number: 4262
the m6 are supposed to be good midbass i would run it 60-70 on up to whereever your tweet starts to sound stressed. i know cdt tweets dont like to play low so somewhre in the 3.5-4k region id start playing around with for the tweets
Username: Bernymac
Cambodian
Post Number: 2631
I got this from CDT
M6 @ 80hz-3khz - 100W, 200W peak "music"
M6 @ 80hz-300hz - 100W, 200W peak "music"
M6 @ 300hz-3khz - 200W, 400W peak "music"
M6 @ 300hz-3.5khz - 200W, 400W peak "music"
Drt25 @ 3khz and up - 100W, 200W peak "music"
Drt25 @ 3.5khz and up - 120W, 240W peak "music"
Home > Message Board > Car Audio > Speakers > Archive through June 02, 2007 > Cdt hd-62/m6 going active frequency r... [ « Previous ] [ Next » ]
