Thread: 140 amp alt |
Silver Member Username: Solobaric4life
Post Number: 772 Registered: Jan-07
| Posted on Monday, May 07, 2007 - 12:56 am: |
i was wonderin would a 140a be good enough for zx2500.1? if not would it be good enough for 2 memphis prd1000.1's? cause the biggest amp alt i found was 460$ + 40$ shipping, and it wasnt much bigger 140a 144$, 200a 460$, thats why i kinda wann stay with the 140 ohh and i will have either 1 or 2 EXTRA 1000 amp everstart batts for 69 a piece, for back in trunk |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1304 Registered: Nov-04
| Posted on Monday, May 07, 2007 - 01:05 am: |
No, 140A is not enough for zx2500.1. Are you sure iraggi doesn't have a big enough alt? You may need to just get like a 300A alt that doesn't fit as is and get another set of brackets to get it mounted in there. I'm not sure of your budget for all this, but maybe some of the more expensive companies like ohio gen or hoalternators.com can make a more powerful one for your car? BTW what kind of a car is it and what year? |
Post Number: 775 Registered: Jan-07
| Posted on Monday, May 07, 2007 - 01:09 am: |
its is a 85 oldsmobile cutlass salon, thanks a lot oleg, cause ill be looking at those rite now |
Post Number: 776 Registered: Jan-07
| Posted on Monday, May 07, 2007 - 01:11 am: |
ohh and a oldsmobile 307 motor |
Santa Monica,
CA
Post Number: 1307 Registered: Nov-04
| Posted on Monday, May 07, 2007 - 04:44 am: |
If you have a large budget, try getting quotes from these companies: motorcityreman.com hoalternators.com ohiogen.com excessiveamperage.com is a cheaper option and i personally own their alt - i highly recommend. Btw did you contact iraggi for the alt? |
Silver Member Username: Waterboy2289
Georgia,
DiRtY SoUtH ...
2 18 SX w/ ...
Post Number: 359 Registered: Jan-06
| Posted on Monday, May 07, 2007 - 07:49 am: |
With extra batteries like you will have and a 140amp alt, you will be able to run this amp. I've read that they are very effecient. Kicker designed them for use in daily driver systems, in which people have minimal electrical upgrades. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1282 Registered: Mar-04
| Posted on Monday, May 07, 2007 - 09:34 am: |
Unless you're one of those people that listens to Bass Mechanik on the verge of clipping 24/7 I would expect 140 to get it done. The '85 olds probably doesn't have a huge stock electrical system so a lot of that 140a will be available for the amp. |
