Thread: Power Acoustik Gothic Series |
Bronze Member Username: Aaron_c
Arkansas
Post Number: 40 Registered: Apr-07
| Posted on Sunday, May 06, 2007 - 11:23 pm: |
Anyone have any experience with these? They are cheap for the power they put out, are they decent amps? |
Bronze Member Username: Da_jay_man06
Crestview,
Florida
U.s.a
Post Number: 29 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 12:03 am: |
my friend has one and i cant figure out how it is as bad as it is and it is only a 820 and hes got 2 12 L5s on it??????????????????????????????????????????? |
Arkansas
Post Number: 41 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 12:11 am: |
What a coincidence, because that's exactly what I'm planning on using it to power...two L5's. Only I'm referring specifically to the OV2-2600. Is this a good amp to push two L5's? Here are the specs on it: http://www.sonicelectronix.com/item_8844_Power+Acoustik+OV2-2600.html |
Crestview,
Florida
U.s.a
Post Number: 30 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 12:21 am: |
i wouldnt because you have to bridge it to get sufficient power imo max power means nothing |
Arkansas
Post Number: 42 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 12:55 am: |
Well, I agree that peak means nothing, but the amp puts out 540x2W RMS at 2 ohms, and the RMS of an L5 is 600W. That seems like a pretty good match, without even looking at max power to me. Am I missing anything here? I don't know much about this. |
Silver Member Username: Solobaric4life
Post Number: 774 Registered: Jan-07
| Posted on Monday, May 07, 2007 - 01:07 am: |
well that amp will not do what it says, they overrate there amps by a lot, i got mine on a memphis prd1000, that is a great amp stays cold and put lil over 1200 true rms if u got the dual 4ohms u can get this http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=373 theve been on sale for a while since theyve got the new models out now |
Arkansas
Post Number: 43 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 01:34 am: |
hmm...thats kinda expensive, thats more than I'm paying for both subs and the box together lol. Maybe I could find one used. |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1305 Registered: Nov-04
| Posted on Monday, May 07, 2007 - 02:27 am: |
The thing is way overrated and I used to have ov2-1600. Not the way to go really. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1283 Registered: Mar-04
| Posted on Monday, May 07, 2007 - 09:42 am: |
IMO it's a decent amp to start with. It ought to give you 400w or so to each sub (if they're dvc 4's - a little less if they're dvc 2's). My concern would be the impact on your car's electrical system. Being a standard class a/b 2 ch means it's not a very efficient amp. For the same price you could go with the Kenwood 9102d. http://www.sonicelectronix.com/item_5901_Kenwood+KAC-9102D.html Same price - same/more power - possibly better reliability - better efficiency. |
Arkansas
Post Number: 44 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 10:18 am: |
The Kenwood amp looks good, I may go for that. Is there any other suggestion for roughly the same price? |
Gold Member Username: Johnfiac
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2674 Registered: Mar-06
| Posted on Monday, May 07, 2007 - 12:06 pm: |
I personnaly wouldnt go with power acoustic... from all expericence ive had with them they literally get get hot enough to cook a egg on the heat sink. I would look into a Mono block as well, they produce much better bass then A\B amps Ive tried the ov2-1600 and the plasma sphere 1920 they both sucked really bad, but if you do go with them the plasma is WAY better then the gothic... but still junk IMO |
Arkansas
Post Number: 45 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 12:45 pm: |
Yeah, I have the TS1920 powering two Comp VR 12's right now. Sounds okay, but I know there is better stuff out there. So even though the Kenwood amp is only 850x1 RMS, it may still produce more power than the PA that supposedly makes 540x2 RMS? I don't understand how they are allowed to overrate like that...I guess automobile manufacturers often do it too though. |
Santa Monica,
CA
Post Number: 1309 Registered: Nov-04
| Posted on Monday, May 07, 2007 - 02:13 pm: |
I'd have to disagree and if it did come down to PA vs kenwood, then I'd take PA. That's just me though. |
Arkansas
Post Number: 46 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 02:28 pm: |
So Oleg, you think the Power Acoustik would make the two L5's hit harder than the Kenwood? THIS IS SO CONFUSING lol |
Lawrence,
Ks
Post Number: 1289 Registered: Mar-04
| Posted on Monday, May 07, 2007 - 03:15 pm: |
I think Oleg would be in a small minority with that opinion |
Arkansas
Post Number: 48 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 03:48 pm: |
So, Optidriven, you think the 850W (425w rms to each sub) would be plenty to power these? I assume it would be louder than my two Comp VR 12's on the Power Acoustik TS1920-2 amp I have now, correct? |
Arkansas
Post Number: 49 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 05:27 pm: |
I just went and looked at the two L5's, they look like this: http://www.sos-auto.ru/userimages/L5.jpg So they are older, right? And are they inferior to the 'new' silver ones? Will they be louder than my Comp VR 12's on my PA TS1920 (as opposed to two L5's on the Kenwood amp)? thanks |
Arkansas
Post Number: 50 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 05:32 pm: |
Eh, I was kinda rambling on my last post...basically, would you replace two 05CVR 12's with two of the L5 12's in the link above? thanks again |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 2178 Registered: Jul-06
| Posted on Monday, May 07, 2007 - 06:47 pm: |
PA and Kenwood amps both suck, don't waste your money on them |
Arkansas
Post Number: 51 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 06:54 pm: |
Hey M.S., while you are online, do you think the black L5 (older model) would be considerably louder than my Comp VR's, all other things equal? And would you pay $250 for two of the L5's in a sealed box? Or is that kind of a bad deal, could I do better on ebay somewhere? |
Arkansas
Post Number: 52 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 08:19 pm: |
And of course, M.S., what amp would you suggest, since these two brands aren't really any good? |
Southeast PA
Post Number: 2186 Registered: Jul-06
| Posted on Monday, May 07, 2007 - 08:33 pm: |
CVRs over L5s any day. The L5s may be louder on more power but their SQ and build quality is complete crap, same goes for L7s. |
Southeast PA
Post Number: 2187 Registered: Jul-06
| Posted on Monday, May 07, 2007 - 08:36 pm: |
The rule of "you get what you pay for" is extremely true in car audio. Kicker subs (except for CVR and CVX), PA amps, and Kenwood amps are all cheap for a reason....... |
Arkansas
Post Number: 53 Registered: Apr-07
| Posted on Monday, May 07, 2007 - 08:41 pm: |
Ahh, so you'd suggest that I keep my Comp VR's? I'm looking to upgrade the system as a whole, so another option would be keep the subs and swap amps out. The subs are both 2-ohms (ordered 4 ohm, but they sent me the wrong ones, said it was my fault), so what would be a good amp to replace my TS1920-2? Also, the guys who installed it said that since they are 2-ohm, they wouldn't be as loud on my amp as 4-ohms would be. Can this be fixed with another amp? thanks for answering my ton and a half questions lol... |
Southeast PA
Post Number: 2188 Registered: Jul-06
| Posted on Monday, May 07, 2007 - 08:48 pm: |
That amp should already be giving those subs full power, that is if they wired it right. (two 2-ohm subs wired in series is 4 ohms, then wired to the amp in bridged mode) If you want to upgrade, you're gonna need new subs and an amp. Post what budget you have in the subwoofer section and you will get plenty of suggestions. |
Santa Monica,
CA
Post Number: 1312 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 07:19 pm: |
Aaron, when I gave my opinion about the amps, we were talking about a slight quality advantage one may have over the other - I went with PA, I've owned PA. Neither of those amps are anything to brag about in terms of power or quality. A solid bang for the buck is always kicker amps - they're not really cheap and not really over the board expensive. Lower quality, but more affordable is hifonics and we recommend that brand a lot to people on a very tight budget. Most of the time if you can afford PA or Kenwood, you should be able to afford some of the hifonics brutus amps. Anyway, the budget is always key in making a good suggestion for your set up. |
Arkansas
Post Number: 64 Registered: Apr-07
| Posted on Tuesday, May 08, 2007 - 07:36 pm: |
Thanks for the post Oleg. I've got a thread going in the subwoofers section about building an entire new system. I plan to go with two AudioQue SD2.5 12's, and I'll be undecided on the amp until the time comes to buy it, because it will depend on my current budget in about three weeks or so. I'll either go with a Hifonics or an Orion, depending on how much cash I have. |
Santa Monica,
CA
Post Number: 1314 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 07:48 pm: |
Nice. Orion HCCA-D2400 would be awesome for those subs. It's a great amp. |
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2683 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 01:20 am: |
fu<k that get a sony xplode, those things bang!  |
