Thread: (2) 05 Comp VR's- best amp? |
Bronze Member Username: Aaron_c
Arkansas
Post Number: 39 Registered: Apr-07
| Posted on Sunday, May 06, 2007 - 10:57 pm: |
I currently have a Power Acoustik TS1920-2 amplifier pushing my two 2-ohm subs (bought 4-ohms, they sent me the wrong speaker, and wouldn't take it back). What's a better amplifier for a similar price ($150ish) to push these? This PA amp is only 2 ohm stable. thanks, Aaron |
Silver Member Username: 04redmach1
Columbus,
GA
Post Number: 672 Registered: Mar-06
| Posted on Tuesday, May 08, 2007 - 07:36 pm: |
Are they dual 2's or single 2's. What is rms on them? Kevin |
Gold Member Username: Ctmike
Ct.
Post Number: 4285 Registered: Feb-06
| Posted on Tuesday, May 08, 2007 - 08:12 pm: |
if thier compvr's then there dual 2ohm vc (i think the only kicker line that comes single vc is the comps, i believe) and i think the rms is about 500w. they take about 300-600wrms daily in my opinion. maybe more if smart about it and it's clean power. i was giving my 15" cvr about 800wrms, give or take, daily for a couple months with no problem. you could look into a kicker zx750.1, that'd be a good match. |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1315 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 09:28 pm: |
That's a really small budget, Aaron. Can you hang on a bit and get the zx750.1? It's $240 shipped on eBay and it's really solid. |
Arkansas
Post Number: 65 Registered: Apr-07
| Posted on Tuesday, May 08, 2007 - 09:34 pm: |
Well I could, but my entire system is for sale . I decided to just start from scratch, so I'm going with two AudioQue SD2.5 12's and either a Hifonics amp or an Orion amp, depending on my cash flow at the time. I'm using this money from selling everything to help fund this lol. |
Santa Monica,
CA
Post Number: 1318 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 09:41 pm: |
Then I suppose you can run them off a hifonics bxi1206D since you're on a tight budget...it should be pretty decent. |
