Thread: Speaker powering ? |
Silver Member Username: Blkwardog
Adel,
Iowa
Usa
Post Number: 130 Registered: Mar-06
| Posted on Sunday, May 06, 2007 - 07:54 pm: |
alrite srry if this is a stupid question but i was wonderin if i cut off power from my rear speakers wen i got my sub in, could i run two channels off my h/u and giv my two front speakers twice the power?? |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1308 Registered: Nov-04
| Posted on Monday, May 07, 2007 - 05:01 am: |
Yes. |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 4246 Registered: Jan-06
| Posted on Monday, May 07, 2007 - 12:58 pm: |
no i dont think so |
Adel,
Iowa
Usa
Post Number: 131 Registered: Mar-06
| Posted on Monday, May 07, 2007 - 01:15 pm: |
lol well now there are two different opinions so if i can jus get a few more ppl to look at this |
Santa Monica,
CA
Post Number: 1310 Registered: Nov-04
| Posted on Monday, May 07, 2007 - 02:17 pm: |
Sorry, blkwardog, I misunderstood your typing. I thought you meant if you bridged 2 channels. If you're simply disconnecting 2 channels, the other 2 don't get any more power. If you bridge both sets of channels, then each bridge would give you twice as much power or something similar. |
West palm,
Florida
Post Number: 4248 Registered: Jan-06
| Posted on Monday, May 07, 2007 - 03:09 pm: |
i dont think you can bridge the channels on a HU though oleg, unless the HU says you i wouldnt |
Santa Monica,
CA
Post Number: 1311 Registered: Nov-04
| Posted on Tuesday, May 08, 2007 - 07:09 pm: |
I think he wants to run rear speakers off the HU and front off the amp, am I right, blkwardog? Anyway, you can't bridge HU, but you can bridge bridgeable amps. |
Silver Member Username: Clouduz
Post Number: 194 Registered: Jun-06
| Posted on Tuesday, May 08, 2007 - 07:59 pm: |
if you mean powered off the Hu i wouldn't most are made to be bridged, if you mean an external amp, yep thats the way to go just make sure you have your ohm load correct |
Adel,
Iowa
Usa
Post Number: 133 Registered: Mar-06
| Posted on Wednesday, May 09, 2007 - 09:49 am: |
no i was jus talkn off a h/u with no amp. but u guys are sayin i shouldnt even try to bridge it into the front two then? i was jw anyway cuz one of my back speakeres is blown and wen i get my sub in i plannd on disconnectin the rears |
Santa Monica,
CA
Post Number: 1337 Registered: Nov-04
| Posted on Wednesday, May 09, 2007 - 12:32 pm: |
Just disconnect the rears and leave others as is. |
