Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Crimping Power Cable Terminal Tips
Author Thread: Crimping Power Cable Terminal Tips
Username: Jayem
What do you guys use to crimp terminals to 4 awg wire? I can't find any reasonably priced crimping tools that'll do the job, the only ones I can find are 6mm ratchet types which are unsuitable. The long heavy duty ones cost way too much.
Hammer good enough? How about a bench vice?
Username: Mmaudioconcepts
Murray, KY
Post Number: 132
if u crimp one side of the terminal at a time it is much easier, it can even be done with the right pair of plyers
Username: Nd4spd18
Southeast PA
Post Number: 2157
" How about a bench vice? "
That's what I use for 1/0, lol. But you should also solder the connection since crimping alone does not always hold real well, especially if you're using a vice and not a real crimping tool.
Username: Nd4spd18
Southeast PA
Post Number: 2158
http://www.bcae1.com/installationprimer.htm
Scroll a little less than halfway down the page
Username: Jayem
Thanks for that link MS, lots of useful info.
Username: Rovin
My 1 12 Atom...
Post Number: 11435
i normally use bench vice or vice grip.....
Username: Waterboy2289
Georgia, DiRtY SoUtH ...
2 18 SX w/ ...
Post Number: 360
I crimp by inserting the 1/0 into the ring terminal, then laying it on the concrete and pounding it with a hammer, then wrapping it tight with electrical tape. After reading a lot of peoples suggestions on how to crimp 1/0, this seemed to be the most used method(believe it or not).
Username: Th3pwn3r
Post Number:...
Post Number: 2432
"" How about a bench vice? "
That's what I use for 1/0, lol. But you should also solder the connection since crimping alone does not always hold real well, especially if you're using a vice and not a real crimping tool."
Word.I told people that I have used a vice and still pulled them off with my bare hands on here and a few sally boys on here said I was full of sh1t.I personally use the set screw terminals but when I do have to use crimp on style I reccomend vice crimping,soldering and then electric tapeing the fugg out of it and pull on it to see if she comes loose.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Crimping Power Cable Terminal Tips [ « Previous ] [ Next » ]
