Thread: Amp Probelms |
New member Username: 1shibby1
Post Number: 1 Registered: May-07
| Posted on Sunday, May 06, 2007 - 06:45 am: |
I have a NBN 1200watt 2 chanel amp, a 12" plye 1200watt sub, A jvc headunit. I had to unplug head unit the other day to get into the air con, I pluged it all back in exactly the same, Then i left and noticed the sub wasnt working and neither was amp, So i re wired everything from battery to amp to sub, still nothing so i tested volt meter, at the bettery 12.44v and at sub 12,43v and when i turn car on i get 4.67v at amp, so im guessing that there isnt enough power getting to the amp, so it wont turn on, i have checked everything i can think of, replaced all fueses even, Please help me |
Gold Member Username: Logan__tille
Hamilton,
Indiana
United states
Post Number: 7200 Registered: Feb-06
| Posted on Sunday, May 06, 2007 - 10:00 am: |
Remote wire? |
Gold Member Username: Ctmike
Ct.
Post Number: 4243 Registered: Feb-06
| Posted on Sunday, May 06, 2007 - 10:24 am: |
"I have a NBN 1200watt 2 chanel amp, a 12" plye 1200watt sub" could be the problem right there. |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 2365 Registered: Mar-06
| Posted on Sunday, May 06, 2007 - 10:58 am: |
Check ground. A bad ground will limet the amount of current flow. |
