Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Subs on amp... not ok?
Author Thread: Subs on amp... not ok?
Username: Johnfiac
A-ToWn, 152-153db Da...
My wangers b...
Post Number: 2657
I was thinking but never tryed it... if you have 2 DVC 1ohm subs and wire one in series and the other in paralel you have 1 at 2ohm and 1 at .5ohm now say you put both of those in series and have 2.5ohm and connect them to the amp... the sub running at .5ohm will be getting alot more power then the sub at 2 ohm right? Since it still has less resistance on the amp then the other...thats all right isnt it?
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1732
I've also wonderd, but i think thats right, the .5 would get more power than the 2...seems right anyways.
Username: Nd4spd18
Southeast PA
Post Number: 2128
You're correct, one sub would get more power than the other if you did that. Not good.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Subs on amp... not ok? [ « Previous ] [ Next » ]
