Thread: Can u connect 3 subs to one amp ??? |
Bronze Member Username: Banginscrew
Post Number: 55 Registered: Dec-05
| Posted on Saturday, May 05, 2007 - 12:04 pm: |
i used to have 2 type X's with a Orion 2500D amp and i blew one my my subs so i got 2 JL Audio W6s D2 V4...there only 400 watts a piece so its 800 together... i was wondering if i could add another sub and jsut connect them all to once amp... how could i do this and still get max power from each sub... i was gunna add my other Type X that i didnt blow and all subs are 4 ohms.. can i do this |
Gold Member Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1727 Registered: Feb-06
| Posted on Saturday, May 05, 2007 - 12:27 pm: |
ummm...u could....but i WOULDNT mix diff. types of subs together...if u really wantd to u could wire to .6ohms or 2.333ohms |
Silver Member Username: Jonesp
Post Number: 252 Registered: Sep-05
| Posted on Saturday, May 05, 2007 - 12:30 pm: |
do it see if you like it. if you do great. if you dont just un hook it |
DiRtY 5oUtH ...
Post Number: 1730 Registered: Feb-06
| Posted on Saturday, May 05, 2007 - 12:33 pm: |
id prolly wire to 2.3ohms when u do it tho, dont wanna screw up the amp, itll take alot of current to run it at .6ohm, plus itd prolly blow the JLs or clip them all to death if ur bang for a while. |
Gold Member Username: Johnfiac
A-ToWn,
152-153db Da...
My wangers b...
Post Number: 2656 Registered: Mar-06
| Posted on Saturday, May 05, 2007 - 12:46 pm: |
If you have a good chargin system run the .6ohm ;) but are all the subs sealed.. ported.. tuned the same? ect... if not i dont really kno where you want to set the freq. on the amp.. |
Silver Member Username: Wolf_hound
Post Number: 190 Registered: Sep-05
| Posted on Saturday, May 05, 2007 - 01:09 pm: |
run them at 2.3..... |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1298 Registered: Nov-04
| Posted on Sunday, May 06, 2007 - 02:12 pm: |
I replied to this in another thread, but (4+4)/3=2.667ohm, not 2.3ohm. Anyway, that's really the only way to wire them because at 0.6ohm the amp will produce too much power for those subs. Is the amp even stable 0.667ohm?? |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 2145 Registered: Jul-06
| Posted on Sunday, May 06, 2007 - 02:49 pm: |
Regardless of how it's wired, you don't want to run different types of subs together. |
Platinum Member Username: Rovin
My 1 12 Atom...
Post Number: 11437 Registered: Jul-05
| Posted on Sunday, May 06, 2007 - 10:25 pm: |
^^^i fully agree with MS ..... |
Silver Member Username: Solobaric4life
Post Number: 773 Registered: Jan-07
| Posted on Monday, May 07, 2007 - 01:01 am: |
"i used to have 2 type X's with a Orion 2500D amp and i blew one my my subs" arent those rated 1000rms a piece?, some ppl on here is using same amp on 2 type r 12's rated at 500rms a peice and not blow them but def not mix subs |
