Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Can u connect 3 subs to one amp ???
Author Thread: Can u connect 3 subs to one amp ???
Username: Banginscrew
Post Number: 54
i used to have 2 type X's with a Orion 2500D amp and i blew one my my subs so i got 2 JL Audio W6s D2 V4...there only 400 watts a piece so its 800 together... i was wondering if i could add another sub and jsut connect them all to once amp... how could i do this and still get max power from each sub... i was gunna add my other Type X that i didnt blow and all subs are 4 ohms.. can i do this
Username: Oleg
Santa Monica, CA
Post Number: 1297
You usually don't want to mix different subs and especially if running them off the same amp. 3 of those subs don't match up well with that amp...if you connect 3 W6s, their coils should be in series and the subs themselves wired in parallel to each other to achieve a 2.667ohm load. You'll need about 1200W rms for all 3 and that orion will give you less than 1000W into 2.667ohms.
Username: Nd4spd18
Southeast PA
Post Number: 2144
^^^ Yeah what he said. Never mix different subs together.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Can u connect 3 subs to one amp ??? [ « Previous ] [ Next » ]
