Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Help with Sub Amp Settings!
Author Thread: Help with Sub Amp Settings!
Username: Nordy
Hi I just bought a new Alpine MRP-M850 to power my Cerwin Vega 12 Max Subs which run at 2ohm. Can someone please help me with the settings on this amp as I am pretty new to all this?
The Subs are in a 2x12" Sealed enclosure, I am trying to get the best results from this amp and subs.
Thanks in advance...
Username: Freezeman_7
Lindsay, Oklahoma
U.S.A
Post Number: 1021
was the rms of the sub?? and the vc?? prolly svc.. but ill need to know that...
Username: Nordy
The rms is 800w at 2ohms as I have it wired at present, whats VC and Prolly SCV?
Username: Wrencher
Brighton, Illinois
Post Number: 20
He means voice coil and probably single voice coil.
Username: 420alldaylong
Post Number: 1648
http://www.cerwinvega.com/vmax.php
If there dual 2ohm you can use both subs on that amp. If there dual 4ohm you can use one on that amp.
Heres how you would wire them.
http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=4o hm_dvc&x=134&y=13
http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=2&impedance_of_subs=2o hm_dvc&x=128&y=6
I hope this helps you out.
Post Number: 1649
Oh yeah the amp setting depends on your volts on your head unit.
http://www.bcae1.com/ (gain setting)
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Help with Sub Amp Settings! [ « Previous ] [ Next » ]
