Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Need a little help
Author Thread: Need a little help
Username: Splsq
Chesterland , Ohio
Post Number: 212
ok well i have a Hifonics Zeus 600 watt 2 channel amp powering 2 12inch Kicker L5s so im only giving them 300 watts each and they can handle 600 and i was wondering would i have to get a new battery if i wanted to get another amp so id have 2. Cause i no i would need a fuse block or whatever it is and another set of wires but i just wanna no if i would need another battery or what i need.
thanx
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4561
tell us the size of your alt. I think you might need a HO alt.
You should leave that zeus for speakers and grab a class D for subs
Username: Splsq
Chesterland , Ohio
Post Number: 213
i have no idea what the alt is its in a 2005 Saturn Ion. thats all i no.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Need a little help [ « Previous ] [ Next » ]
