Thread: Audiobahn Amp ... Protection Light ... Help Needed |
New member Username: Dk2000
Post Number: 1 Registered: May-07
| Posted on Tuesday, May 01, 2007 - 07:32 pm: |
I have an Audiobahn A8000T. Yesterday on the ride home, my sub cut out. No pop, no warning. Doing some investigating today, the protection light will go off when I remove the RCAs. Either left or right RCA will put it into protection mode. I'm about to go out and test with an MP3 Player with 1/4 inch to RCA. Any other suggestions? This sudden cut out has me baffled. It's been working fine for almost 3 years. |
Silver Member Username: 04redmach1
Columbus,
GA
Post Number: 620 Registered: Mar-06
| Posted on Tuesday, May 01, 2007 - 08:46 pm: |
Well, you got 3 years out of an A-bahn amp, you did pretty good grasshopper. May need to look at another amp. Kevin |
Post Number: 2 Registered: May-07
| Posted on Tuesday, May 01, 2007 - 09:14 pm: |
lol, yeah, all things considered, 3 years isn't bad... I'm gonna check a few more things... A new system will have to wait till I get a new car... the 93 dakota it's in is finally falling apart! |
Silver Member Username: Mike_16
Burlington,
Wisconsin
Us
Post Number: 553 Registered: Aug-06
| Posted on Tuesday, May 01, 2007 - 11:29 pm: |
lol.. my bro had that 2400 legacy class d amp and ha dit for about 2 weeks of use then tok it out of teh car and hooked it up and sam eexact problem liek the light owuld be on then u plug teh rca's in and liek the subs woudl do soem wierd a.s sh.t and it woudl go into protect.. |
Silver Member Username: Sinful_systems70
15 INCH WANG...
Post Number: 843 Registered: Nov-06
| Posted on Tuesday, May 01, 2007 - 11:55 pm: |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 2108 Registered: Jul-06
| Posted on Wednesday, May 02, 2007 - 10:51 pm: |
^^^^^ As usual, Sinful's clip art pretty much says it all, lol. |
Gold Member Username: Carguy
Post Number: 6194 Registered: Nov-04
| Posted on Thursday, May 03, 2007 - 11:02 am: |
Complete your test with the portable cd player. Double check your level/gain setting on the amp. |
Post Number: 3 Registered: May-07
| Posted on Thursday, May 10, 2007 - 12:59 am: |
Good news... even though the inline fuse on the power line looked good, I swapped it out and the system works fine. I still to this day cant see a problem with the old fuse. So for all the haters, I get more life out of my Audiobahn  |
