Home > Message Board > Car Audio > Head Units > Archive through June 23, 2007 > DEH-7800MP...good or bad
Author Thread: DEH-7800MP...good or bad
Username: Mtx7500
Post Number: 12
redoing my system and looking for a hu. i'm really leaning towards this one, but just HOW good is it?
Username: Ctmike
Ct.
Post Number: 4186
it's pioneer so you know it's good. but that is just the regular pioneer right, not the premier?
Username: Mrbass
Long beach, California
United state
Post Number: 100
not much of a difference, their the same but the premier has extended warranty
Username: Sinful_systems70
15 INCH WANG...
Post Number: 848
Premier has higher voltage RCA's and I believe has an extra set as well! There is a big difference between Pioneer and Pioneer PREMIER. Reg Pioneer is 2.5 volt and PREMIER is 6.5v. I would be careful what internet site you get your info/specs from... JMO
Username: Dkchillin
Vermont
Post Number: 452
Not sure where Sinful is getting his information but Usaka is right. The only tangible difference between the 7800 and the 780 (premier version) is the extra year warranty. Go to www.pioneerelectronics.com and look both decks up for yourself. The two units have th same number of preouts (3) and the samve voltage (5V). In years past the standard and Premier versions of the same deck used to be different, much like Sinful was saying, but in this case the two are very similar. It's been said that Pioneer uses "higher quality parts" for the Premier versions but I've never really seen or heard anything to prove that theory.
Home > Message Board > Car Audio > Head Units > Archive through June 23, 2007 > DEH-7800MP...good or bad [ « Previous ] [ Next » ]
