Thread: Is my gain right??? |
Silver Member Username: 2pacalypse1971
Sandusky,
Oh
Post Number: 350 Registered: Jul-05
| Posted on Tuesday, May 01, 2007 - 09:09 am: |
i have a 4v headuint and a mbquartRAA1000 and all the adjustment knobs are as i expected, with the lowest number being on the bottom left hand side and the higher one on the bottom right side, except for the gain, it is in a switch positioin where 8v is on the bottom left and .15 volts is on the bottom right, i basically have it set to the exactly middle, is this right or should it be less or more |
Gold Member Username: Ctmike
Ct.
Post Number: 4182 Registered: Feb-06
| Posted on Tuesday, May 01, 2007 - 09:11 am: |
do you have a dmm? use that if it's available. |
Sandusky,
Oh
Post Number: 351 Registered: Jul-05
| Posted on Tuesday, May 01, 2007 - 12:05 pm: |
nope don't have one o fthem, i don't know, i think i got it about right because it soudns almost perfect and no clipping or anything and i figure if 8 is the highest it goes, right in the middle shoudl be about 4 to match my hu |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 2103 Registered: Jul-06
| Posted on Wednesday, May 02, 2007 - 10:28 pm: |
" i think i got it about right because it sounds almost perfect and no clipping " You don't know that unless you put an oscilloscope on it. " i figure if 8 is the highest it goes, right in the middle should be about 4 to match my hu " Doesn't work that way, ya have to do it the right way: Use this to calculate what voltage you amp should output: http://www.subwoofertools.com/forum/setgain.asp If you want, use this tutorial it explains it better: http://mobile.jlaudio.com/support_pages.php?page_id=143 |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 2384 Registered: Jul-06
| Posted on Thursday, May 03, 2007 - 03:21 pm: |
"i have a 4v headuint and a mbquartRAA1000 and all the adjustment knobs are as i expected, with the lowest number being on the bottom left hand side and the higher one on the bottom right side, except for the gain, it is in a switch positioin where 8v is on the bottom left and .15 volts is on the bottom right, i basically have it set to the exactly middle, is this right or should it be less or more" Marcus,from now on learn how to do something before you do it.I'm not trying to be an azzhole but I also don't want you to blow up your equipment.Next time you're not sure how to hook something up just come on here,post about it and wait a little while for a response,that way you won't damage anything. |
Silver Member Username: Killswitchjd
Post Number: 510 Registered: Apr-06
| Posted on Thursday, May 03, 2007 - 03:47 pm: |
Trial and error never hurts as long as you notice clipping, I say ur good... |
Silver Member Username: J_c_wheeler8
Columbus,
IN
United States
Post Number: 440 Registered: May-06
| Posted on Friday, May 04, 2007 - 03:50 pm: |
how can i get a hold of a test tones cd? |
