Thread: Comp help. |
Bronze Member Username: Aaronjp1990
Lerwick,
Shetland
Uk
Post Number: 79 Registered: Apr-06
| Posted on Friday, April 27, 2007 - 02:46 pm: |
whats would the best comps be to go with a 12 w6? will that can run of headunit till i get my amp (75rms) |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 4146 Registered: Jan-06
| Posted on Friday, April 27, 2007 - 03:40 pm: |
how much do you have to spend?!!!! and are you set on getting an amp that does 75rms? |
Lerwick,
Shetland
Uk
Post Number: 81 Registered: Apr-06
| Posted on Saturday, April 28, 2007 - 07:24 am: |
yes going to get a jl 400/4 when i have the money. have about £300 to spend about $400-500 i think |
Lerwick,
Shetland
Uk
Post Number: 82 Registered: Apr-06
| Posted on Saturday, April 28, 2007 - 07:25 am: |
sorry i mean 300/4 not with it today |
West palm,
Florida
Post Number: 4151 Registered: Jan-06
| Posted on Saturday, April 28, 2007 - 12:23 pm: |
well alot of higher end speakers love alot of power you may want to look into rainbow slc 265 and also the rainbow germaniums which need 150-200rms each. your in the UK and they are made in germany so they might be easy to find. what brands do you have access to? |
Lerwick,
Shetland
Uk
Post Number: 83 Registered: Apr-06
| Posted on Saturday, April 28, 2007 - 03:01 pm: |
jl audio, mb quart, kicker, Rockford fosgate, genesis, orion, mtx, focal, audiobahn. and the usual big brand stuff. |
Lerwick,
Shetland
Uk
Post Number: 84 Registered: Apr-06
| Posted on Saturday, April 28, 2007 - 03:05 pm: |
and rainbow sorry |
Lerwick,
Shetland
Uk
Post Number: 85 Registered: Apr-06
| Posted on Saturday, April 28, 2007 - 03:07 pm: |
i can get anything of this site if u want to have a look http://caraudiosecurity.com/shop/home.html its the best place i have found in the uk O.o |
West palm,
Florida
Post Number: 4156 Registered: Jan-06
| Posted on Saturday, April 28, 2007 - 05:35 pm: |
http://caraudiosecurity.com/shop/product/products_id/2853.html http://caraudiosecurity.com/shop/product/products_id/5172.html http://caraudiosecurity.com/shop/product/products_id/5573.html http://caraudiosecurity.com/shop/product/products_id/3533.html http://caraudiosecurity.com/shop/product/products_id/3981.html any of the listed would be nice. i would probly choose the dls then the rainbow then the apline type x then dimond and the PG's if you want to keep it cheap, they are still good speakers but i would highly suggest getting an amp that does more power something in the 125-150rms range |
Lerwick,
Shetland
Uk
Post Number: 87 Registered: Apr-06
| Posted on Saturday, April 28, 2007 - 05:49 pm: |
any suggestions on an amp? and will it be safe to run all that components on that size even tho the rms is around 75? |
West palm,
Florida
Post Number: 4159 Registered: Jan-06
| Posted on Saturday, April 28, 2007 - 06:07 pm: |
the only speakers on that list i would suggest running 75 or less to are the PG's or 75 on the rainbows wouldnt be bad, but i have 150 on mine. with 75 they just wont get as loud. i wouldnt run any of the other speakers i listed without more power. i know the type x are rated at 75 but i ran 75 to a pair of type R and they just didnt sound very good compared to when i put 125 on them http://caraudiosecurity.com/shop/product/products_id/2894.html http://caraudiosecurity.com/shop/product/products_id/3675.html this is the amp im useing and its very nice. also good price http://caraudiosecurity.com/shop/product/products_id/5557.html http://caraudiosecurity.com/shop/product/products_id/3148.html |
Lerwick,
Shetland
Uk
Post Number: 88 Registered: Apr-06
| Posted on Saturday, April 28, 2007 - 06:15 pm: |
what should i run on theys? http://caraudiosecurity.com/shop/product/products_id/3984.html if they are any use? and that is a nice amp but i think its to powerful for that comps? |
West palm,
Florida
Post Number: 4167 Registered: Jan-06
| Posted on Monday, April 30, 2007 - 07:23 pm: |
i didnt see those on that site i dont know how i missed them. anyway they are great speakers they will probly be my next set actually. anyway iv talked to a few people who are dealers or know about about them and it will take anywhere from 150-200rms so just look for an amp that fits into that. i wouldnt worry about over powering them you just need to set the gain correctly and make sure they are getting a clear signal. you should also be able to tell by ear when the speaker is stressed and that will let you know to turn it down. |
Lerwick,
Shetland
Uk
Post Number: 95 Registered: Apr-06
| Posted on Tuesday, May 01, 2007 - 02:40 am: |
i am assuming that they are 4 ohm speakers? so its a 2 or 8 ohm i need to run them at? and where would i find the target voltage for them? |
West palm,
Florida
Post Number: 4173 Registered: Jan-06
| Posted on Tuesday, May 01, 2007 - 03:10 pm: |
they are single 4ohm so the amp will see a 4ohm load if its one speaker per channel. or in this case the speaker+tweet+xover per channel is still a 4ohm load on the amp. subwoofertools.com has a gain setting tutorial, the best way IMO is to set it by ear. just put it on your fav song and to the loudest youd listen at and listen to see if the music is distorting or if everything sounds natural. |
Lerwick,
Shetland
Uk
Post Number: 96 Registered: Apr-06
| Posted on Wednesday, May 02, 2007 - 11:54 am: |
ok think am going to go with http://caraudiosecurity.com/shop/product/products_id/3984.html and http://caraudiosecurity.com/shop/product/products_id/3675.html thanks for all your help :D |
West palm,
Florida
Post Number: 4195 Registered: Jan-06
| Posted on Wednesday, May 02, 2007 - 02:58 pm: |
that will be a nice combo. |
