Thread: Deck question???/ |
Bronze Member Username: Thump510
Oakland,
Ca
U.s
Post Number: 32 Registered: Dec-06
| Posted on Friday, April 27, 2007 - 01:13 am: |
i have an 85 camry and i wanna noe how 2 hook it up i have some wires inside da dash so i dont think i have 2 do any wiring or do i? |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1134 Registered: Nov-04
| Posted on Friday, April 27, 2007 - 02:52 am: |
probably a wire harness ppl have been saying to check out www.the12volt.com for info |
New member Username: Dkstr24
Post Number: 2 Registered: May-07
| Posted on Thursday, May 03, 2007 - 01:10 pm: |
I have a 1996 pontiac grand AM and i hooked up the wires with the scoche wiring harness but have the yellow wire and dont know were to put it can you help me? |
Silver Member Username: Rtyauch301
Post Number: 150 Registered: Aug-06
| Posted on Thursday, May 03, 2007 - 01:14 pm: |
is thair a red and yellow wire on your hu as far as i know the yellow u need 2 hook 2 the constant 12volt n the red to the switched i know alot of people wire them to gether on the switched hot but then theirs no memory on the radio |
