Home > Message Board > Car Audio > Head Units > Archive through June 23, 2007 > Panasonic Aux IN problem
Author Thread: Panasonic Aux IN problem
Username: Staticx
hey guys i recently got a zune player and hooked it up to my aux in on my deck. Prob is its extremely quiet even with the deck turned all the way up and the zune all the way up. any idea? Deck is 1.2 yrs old panasonic cq c5410
Username: Dkchillin
Vermont
Post Number: 445
First, make sure your patch cable (from the Zune to the deck) is pushed in all the way on both ends. Many of them will actually snap into place when they're fully inserted and if they're not you'll get a mono signal.
If that's not the issue then you may want to look into a small pre-amp since the MP3 player isn't designed to pump out that strong a signal and your deck may not be processing/amping it enough for your volume tastes.
Username: Mrbass
Long beach, California
United state
Post Number: 91
i would just prefer you to get a new deck that wont have any problem with the aux
Username: Nd4spd18
Southeast PA
Post Number: 2061
^^^^ Do not listen to this stuff, you don't need no preamp or new HU.
Your HU probably has an "AUX level" or "input level" setting in one of the menus somewhere, and you need to turn it up.
Username: Staticx
the deck i have has no AUX level ir input level setting, ive searched in all the HU menus and looked in the manual
Username: Mrbass
United state
Post Number: 101
thats why i recommend to get a new nice deck that has the aux input
Username: Staticx
it does have AUX INPUT, says right on the cables and manual
Username: Kpa2727
Post Number: 10
u see i have seen this many times and theres to reasons here one its not a true aux its just a input and u can risk toasting ur zune from over working ur zunes amp or ruin your speakers from reverseing a feed thats doing what its not meant to. ur best bet here is just stop cause u will ruin something. some older auxs never even had a preamp on it.if its a true aux ursound will bump out like no tommorrow if it can't do that theres a serious issue and continuing use like that will take its toll eventually. ur best bet if its just stock system then get a transmitter if not then get a new headunit preferably a pioneer but do ur home work alot of pioneers cheeper headunits only have accesory or line in NOT a AUX so do your home work but yes be careful.
Username: Kpa2727
Post Number: 11
i reviewed the pdf manual and u say its a cq c5410 but the aux is only offered on the cq c5410 "U" model u might be plugged into the cd changer in line u think is aux in that case u have no aux, sorry but its the best i can do for you.
Home > Message Board > Car Audio > Head Units > Archive through June 23, 2007 > Panasonic Aux IN problem [ « Previous ] [ Next » ]
