Thread: Dual 8285 Bypass? |
New member Username: Btlew81
Post Number: 1 Registered: Apr-07
| Posted on Tuesday, April 24, 2007 - 11:08 pm: |
New here...want to get the dual 8285, but also want to bypass so I can watch while driving. Would I use the same CD/DVD method mentioned for older duals? I desperately need some quick help! Thanks |
Relevant Product Info
New member Username: Barbamil
Moscow Russia
Post Number: 2 Registered: May-07
| Posted on Wednesday, May 30, 2007 - 01:41 pm: |
E-Brake wire still grounded at the Steering Column area ** Insert a DVD and let it play until you hear sound ** Using the remote control, Press the STOP button twice ** Enter 26604 ** Press OK |
Moscow Russia
Post Number: 3 Registered: May-07
| Posted on Wednesday, May 30, 2007 - 01:45 pm: |
Please, how to multizone a Dual XDVD 8285.Thanks. |
New member Username: Tone602
Az
| Posted on Monday, June 04, 2007 - 11:32 pm: |
this also worked for my Dual 8183 dvd player... thanx |
New member Username: Cyberalexander
Post Number: 1 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:36 pm: |
Hello, I have a Dual xdvd8285 applies the code for parking bypass, but now when placing the screen in stanby, it is placed in black only about 5 seconds and then reappears video, it is not applied according to the Standby screen, I do? Has something to do bypass brake by code? Thanks. |
