Thread: Infinity? |
Bronze Member Username: Solo67042
Post Number: 37 Registered: Apr-07
| Posted on Friday, April 20, 2007 - 12:06 pm: |
i have just recently replaced my HU and put a sub in my car. i am very pleased with how it sounds and it get plenty loud for me. im sure however there is much better out there.. i am now ready to start replacing the speakers in my car. if i do not plan on running them through a amp will they still sound noticably beeter than the stock speakers? i am looking to spend around 100 dollars per set and have been looking into infinity. what are some suggestions on some speakers? i have 6 1/2s in my front doors and 6x9s in the back. |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 511 Registered: Jun-06
| Posted on Friday, April 20, 2007 - 04:11 pm: |
With your price range, check these out: 6 1/2: http://www.sonicelectronix.com/item_5154_Infinity+Kappa+63.7i.html 6x9: http://www.sonicelectronix.com/item_5024_Infinity+Kappa+692.7i.html alittle more than $100 but, they should be well worth it |
Silver Member Username: Dkchillin
Vermont
Post Number: 435 Registered: Mar-05
| Posted on Saturday, April 21, 2007 - 12:28 am: |
Make sure you take a listen to those Infinity speakers before you buy them, some people love them some don't, they have a distinct sound. As another option in your price range, look into the Polk DB series. |
Silver Member Username: Brynm
Saskatchewan
Post Number: 270 Registered: Jul-05
| Posted on Saturday, April 21, 2007 - 08:46 am: |
Do not use the Infinity kappa's they are designed to be amped as they are only 2 ohm speakers, most HU's are only 4 ohm capable so your likely to burn out the internal amp |
Saskatchewan
Post Number: 271 Registered: Jul-05
| Posted on Saturday, April 21, 2007 - 08:53 am: |
Check out there reference line, you can get a set of new 6012i and 9613i's for a total of 165 shipped in the US http://cgi.ebay.com/Infinity-Reference-9613i-6x9-3-Way-6-x-9-Car-Speakers_W0QQit emZ280106832737QQihZ018QQcategoryZ14942QQssPageNameZWDVWQQrdZ1QQcmdZViewItem http://cgi.ebay.com/Infinity-Reference-6012i-6-5-Coaxial-Car-Speakers-6-1-2_W0QQ itemZ280104919149QQihZ018QQcategoryZ18799QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
