Thread: Best SQ 5.25" Component Speakers |
Bronze Member Username: Fearthisskyy
Carrollton,
Texas
United states
Post Number: 25 Registered: Apr-07
| Posted on Wednesday, April 11, 2007 - 03:29 am: |
Best 5.25" Component Speakers suggestions Budget is preferably $150-200. $250 if there are components out there that are SIGNIFICANTLY better compared to ones in the budget. a few I've been looking at: Focal 130 A1, Infinity Perfect 5.1, Eclipse SC8254 |
Bronze Member Username: Treez
Post Number: 14 Registered: Aug-06
| Posted on Thursday, April 12, 2007 - 12:33 pm: |
Really clean, sounding set of components. will sound great even with 50 watts rms. They lacking a bit in the midbass, but crisp highs. overall .. a great listening experience.. Be sure to check the available space for mounting. |
Bronze Member Username: Dlavante
Tigard,
Or
Post Number: 63 Registered: Feb-07
| Posted on Thursday, April 12, 2007 - 01:59 pm: |
i personally like mb quart Q components but some people say theyre a little harsh http://www.millionbuy.com/mbqqsc213.html they sound really good on 75-100 watts |
Carrollton,
Texas
United states
Post Number: 30 Registered: Apr-07
| Posted on Saturday, April 14, 2007 - 03:11 am: |
Sean, which one are you talking about?? that'd be tight if I got the MB Quart Q bc I'd have the Fi Q and MB Quart Q in there |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1531 Registered: Jan-06
| Posted on Saturday, April 14, 2007 - 02:58 pm: |
^^^^thats a silly reason to get a set of speakers. Rainbow, maybe CDT but CL-e series is about the only thin close to that price range, HD would be much better but more expensive. |
Silver Member Username: Warlok
Orlando,
FL
Post Number: 277 Registered: Dec-05
| Posted on Saturday, May 19, 2007 - 07:30 am: |
I agree with AA. Diamond (HEX)also has some pretty nice comps in that price range. they sound very clean. |
