Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Auto start problem
Author Thread: Auto start problem
Username: Joe718
Hi everyone, quik question. I have a prestige pager alarm, its the old one that has no color on ths screen. My problem is when i auto start the car, my steering is so tight that you can even drive it, but when i start the car normally its ok. Is this a mecahnical problem or is it the alarm? Thanks
Time for a new alarm..
HELLO all DOES ANY KNOW WHAT THE WIRE COLORS ARE FOR A 1977 DODGE PICKUP IGNITION SYSTEM .
raj
Hi!
I have hond accord wagon (1992)model.
Some times in summer when there is hot weather and tempurature out side is too high ,while appling starter it cranks but it doesnot start.when weather temprature is cool it starts immediatlly.Why this happens?
Username: Zacdavis~
Post Number: 91
bill113 and raj, start your own thread, duh
JOSEPH, your alarm if fine, the problem is that you don't have the second or third ignition wire powered during start, this will cause the car's computer to screw up, you probably have an electric power steering pump rather then hydraulic which runs off the motor, it needs to "see" ignition when the car starts so bring it to a pro to tidy up your install :-)
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Auto start problem [ « Previous ] [ Next » ]
