Thread: Audiocontrol EQL or something else |
Gold Member Username: Bernymac
Cambodian
Post Number: 2373 Registered: Sep-04
| Posted on Tuesday, April 03, 2007 - 09:54 am: |
I was thinking about purchasing the audiocontrol EQL Equalizer. Mainly since I have all of my components in the front and no compnents in the rear. I would use the EQL to balance the front components. Actually I might need a 4 channel since theres two components on each door and such. whats your input. |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11780 Registered: Dec-03
| Posted on Tuesday, April 03, 2007 - 11:00 am: |
if you're using a single 2 channel amp to power the front stage, all you need is a single EQL. I used an EQL in my old Festiva before I went to the Alpine 3401 parametric. Great little unit from AC. it's a 1/2 octave EQ. pretty simple set and forget device, but you may still want an RTA for tweaking it when its installed. you'd only need to rent an hour or so of time with the RTA though to set everything. its only got like 13 bands. if you want more control, and multiple channels, AC has a new digital model that's a 1/3 octave 6 channel EQ now.. but its not cheap |
Cambodian
Post Number: 2378 Registered: Sep-04
| Posted on Wednesday, April 04, 2007 - 01:08 am: |
I'm actually going to have two amps. 1 amp for my midrange drivers (4 CDT m6) 1 amp for my tweeters (4 CDT drt25's) I'm going to custom fiberglass my door panels to have two midrages in them and two tweeters each door, all aiming towards the dome light for imaging. So pretty much I'm only going to have a front channel setup, no rears. thats why I thought the AC EQL would be a good choice. Front RCA's into EQL, EQL to AC 6xs, and the 6xs will take it to the amplifiers. Then take it to a professional most likely and get it all tuned up nicely if I can't get it right. So yeah, did I miss anything or am I set to go. |
Cambodian
Post Number: 2393 Registered: Sep-04
| Posted on Wednesday, April 04, 2007 - 09:30 am: |
I notice that in coupes and sedans, the seats are lower, which means the speakers are closer. But I have a suv and the speakers are really far away from me. Should I mount my components up more, lets say, closer to my knee's. Like about 5 inches higher from the floor. Glasswolf, you have a lot of experience, shine something on me =). |
Wisteria,
Lane
Post Number: 11795 Registered: Dec-03
| Posted on Wednesday, April 04, 2007 - 10:14 pm: |
good setup. the SUV shouldn't be a problem. use time correction on the ehad unit to compensate for the difference in left and right channel path lengths |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 2315 Registered: Jul-06
| Posted on Monday, April 30, 2007 - 02:26 pm: |
"good setup. the SUV shouldn't be a problem. use time correction on the ehad unit to compensate for the difference in left and right channel path lengths" That would be good for a single person in the vehicle but what if you have a passenger?The timing would be off wouldn't it? |
Wisteria,
Lane
Post Number: 12020 Registered: Dec-03
| Posted on Tuesday, May 01, 2007 - 05:36 pm: |
yes but who cares. its your car. you can't have perfect imaging everywhere. there has to be a sweet spot. |
Post Number:...
Post Number: 2358 Registered: Jul-06
| Posted on Tuesday, May 01, 2007 - 08:32 pm: |
^Hahaha,GlassWolf,you're selfish! |
Cambodian
Post Number: 2697 Registered: Sep-04
| Posted on Sunday, May 13, 2007 - 11:48 pm: |
lmao. I don't care as well. I don't think they would even notice as much as I will. All they care about is that theres music and its loud. |
Platinum Member Username: Bestmankind
Los Angeles,
CA
Post Number: 12819 Registered: Oct-05
| Posted on Monday, May 14, 2007 - 12:30 am: |
wtf is rob doing in this section. lol. |
Gold Member Username: Tremor1127
Fi Car Audio has got m...
Post Number: 1513 Registered: Aug-06
| Posted on Monday, May 14, 2007 - 10:34 am: |
haha, im only in this section cause i seen your name posted last, had to see if you were giving bad advice... and glasswolf is right, its all about that sweet spot... as chris rock would say, "f ck the passenger, he didnt pay all the money for this rrriiidddeee!" |
