Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > 2 alpine 10" type X subs WHAT AMP DO ...
Author Thread: 2 alpine 10" type X subs WHAT AMP DO I NEED??
Username: Yupimluke
Lovettsville, Va
United states
Hey guys i just bought 2 alpine SWX-1042D 10" subs and im not sure what amps i need to get the best sound possible. I'm willing to pay whatever but would like to keep it low. Thanks for the help.
Username: Nyyfan13
Fi SSD
Post Number: 4523
dual 2 or dual 4 ohm?
Username: Yupimluke
Lovettsville, Va
United states
Dual 4 ohm
Username: 420alldaylong
Post Number: 1293
LUKE
What is low to you?
Username: Yupimluke
Lovettsville, Va
United states
id say about 500-750 range would be great(just because thats what i have at the moment). If i can't get a good sound for that price I'm willing to pay more, But I'm just trying to get ideas now so say whatever you guys think would be a good match for my subs. Btw I'm pretty new at this if you couldn't tell already!
Post Number: 1295
http://www.sonicelectronix.com/item_4238_Hifonics+XX-Hercules.html
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4200
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=2637
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3821
Username: Nyyfan13
Fi SSD
Post Number: 4524
have a thing for hifonics joey? lol
Username: Sheriff
Post Number: 293
Hifonics BXi2006D is what I would go with.
Post Number: 1297
No but they get the job done.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4342
in that range, f*ck hifonics man, unless you're going XX line
Username: Yupimluke
Lovettsville, Va
United states
So what would you say would be the best choice? I want too get the good quality sound and loudness.
Username: Yupimluke
Lovettsville, Va
United states
I'm looking at the Hifonics XX-Hercules but i am still a bit confused! I just wanna make sure, so if i do get the Hercules that will be enough to power my two subs?
Username: Ctmike
Ct.
Post Number: 3738
have any money put away for a charging system upgrade (if you haven't done it already)?
Username: Yupimluke
Lovettsville, Va
United states
I have extra cash that i was going to buy a new radio for but i could get the charging system instead! Do you have any recommendations? And thanks to everyone that has helped, I appreciate it.
Username: James1115
Use a simple...
Post Number: 9872
what type of car do you have? whats the stock alt? chances are you are going to need a HO alt. I would stay clear of hifonics with your budget. You need something that does 2000 watts at 1 ohm. I will look into it a little for you and get back to you.
Username: Yupimluke
Lovettsville, Va
United states
Post Number: 7
Its actually a truck, Its a 99' dodge 2500 extended cab. I'm not sure but i think i have a 105 amp alt. I would like the price pretty low because i have other things to get but i can always wait. Thanks for the help James!
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > 2 alpine 10" type X subs WHAT AMP DO ... [ « Previous ] [ Next » ]
