Thread: Ohms ? |
Silver Member Username: Mike_16
Burlington,
Wisconsin
Us
Post Number: 421 Registered: Aug-06
| Posted on Sunday, April 01, 2007 - 04:10 pm: |
ok so if you have 2 dvc subs that are 2 ohms, an dhave a 1 ohm amp can you hook it up, i used ot know this but i just forgot bout it and how it worked , i think it has to be dual 4 ohm to hook up to 1 ohm right? |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 4520 Registered: Jul-06
| Posted on Sunday, April 01, 2007 - 04:12 pm: |
2 dual 2 ohm subs cant be wired to 1 ohm... 2 dual 4 ohm subs can be wired to 1 ohm... http://www.the12volt.com/caraudio/woofer_configurations.asp |
Burlington,
Wisconsin
Us
Post Number: 423 Registered: Aug-06
| Posted on Sunday, April 01, 2007 - 04:16 pm: |
ok so would it be better to have 2 dual 4 ohm subs and a 1 ohm amp? or would it be better to have 2 dual 2ohm subs with a 4 ohm amp, |
Silver Member Username: Goodie_goop
Midland,
Texas
U.S.
Post Number: 472 Registered: Oct-06
| Posted on Sunday, April 01, 2007 - 04:17 pm: |
two dvc 2 subs can wire to 2ohm u need dvc 1 or dvc 4 to get two subs to a 1ohm load |
Midland,
Texas
U.S.
Post Number: 473 Registered: Oct-06
| Posted on Sunday, April 01, 2007 - 04:20 pm: |
get 2 dual 4 with a 1ohm stable amp you cant run 2 dual 2ohm subs at 4ohms |
Fi SSD
Post Number: 4522 Registered: Jul-06
| Posted on Sunday, April 01, 2007 - 04:23 pm: |
what subs and amp are yuo looking at? 2 dual 4 ohm subs wire to a 1 ohm or 4 ohm load 2 dual 2 ohm subs wire to a .5 ohm or 2 ohm load 2 dual 1 ohm subs wire to a 1 ohm load |
Silver Member Username: Imalik
SD2.5,
New Jersey
Ocean
Post Number: 201 Registered: May-06
| Posted on Sunday, April 01, 2007 - 04:32 pm: |
Your amp is not 1 ohm...its 1 ohm stable...meaning you have a few more wiring options.1-2-4 ohms |
Burlington,
Wisconsin
Us
Post Number: 426 Registered: Aug-06
| Posted on Sunday, April 01, 2007 - 05:10 pm: |
yanks fan i will prolly be runnin 2 12's alpine 4 ohms type r's and i was thinking 2006 hifonics, but unless i could maybe get a lil more money and what would you guys use for them to get the most power outs them? what amp around 300 bucks? |
