Thread: Help with choosing an amp. |
New member Username: Abcmute
Post Number: 1 Registered: Apr-07
| Posted on Sunday, April 01, 2007 - 04:06 pm: |
I have recently bought a Solobaric L7 15" and a Solobaric L5 15" but I don't know what amplifier to buy to make sure they are getting all the power they need. Any suggestions are greatly appreciated. Thanks in advance. P.S. Are there any other things I should consider buying like a capacitor or an extra battery? |
Silver Member Username: Goodie_goop
Midland,
Texas
U.S.
Post Number: 471 Registered: Oct-06
| Posted on Sunday, April 01, 2007 - 04:09 pm: |
what is ur budget for the amp? and you shouldnt run both of those in the car since they are different subs |
Gold Member Username: 420alldaylong
Post Number: 1287 Registered: Sep-06
| Posted on Sunday, April 01, 2007 - 04:24 pm: |
The L5 15" is 750 watts and the L7 15" is 1000 watts are you trying to run both subs. Oh what ohm are the subs. |
Post Number: 2 Registered: Apr-07
| Posted on Sunday, April 01, 2007 - 04:52 pm: |
For the former reply, I don't really have a budget so any suggestions are useful. But why can't I run both together? That doesn't make sense, at least to me. For the latter reply, yes I am trying to run both subs and how do I find out how many ohms they have? |
Post Number: 1291 Registered: Sep-06
| Posted on Sunday, April 01, 2007 - 05:00 pm: |
http://www.sonicelectronix.com/pictures.php?id=3440 |
Post Number: 3 Registered: Apr-07
| Posted on Sunday, April 01, 2007 - 05:08 pm: |
My sub don't look like that, mine is black. What would be a good amp though or should i consider buying two? |
Post Number: 1292 Registered: Sep-06
| Posted on Sunday, April 01, 2007 - 05:27 pm: |
It depends on the ohm. So when you find out what ohm we can help. |
Post Number: 5 Registered: Apr-07
| Posted on Sunday, April 01, 2007 - 05:34 pm: |
On the Kicker website it says either 2 or 4 ohms. Does that help? |
Post Number: 1294 Registered: Sep-06
| Posted on Sunday, April 01, 2007 - 05:38 pm: |
NO It should say some where on the subs. |
Post Number: 6 Registered: Apr-07
| Posted on Sunday, April 01, 2007 - 05:51 pm: |
Oh thats right. They are 2 ohms each. And should I consider buying an extra battery and capacitor? |
Silver Member Username: Sheriff
Post Number: 292 Registered: Jan-07
| Posted on Sunday, April 01, 2007 - 05:55 pm: |
I wouldn't run those two subs in the same car. |
Post Number: 1296 Registered: Sep-06
| Posted on Sunday, April 01, 2007 - 06:01 pm: |
I agree with Corey Dalton don't run them together. If it was me I would run the L7 15" in a vented box with a Hifonics BXi1206 or BX1205. But thats what I would do. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4343 Registered: Dec-05
| Posted on Sunday, April 01, 2007 - 06:17 pm: |
you will need a HO alt and some electrical upgrades btw. Mixing subs is a problem. Is not recommended. Why? because you mix tuning, response and many specs the sub has. |
New member Username: Luvbass
To,
Ca
United states
| Posted on Monday, April 02, 2007 - 01:12 am: |
for the l5 i suggest the zx750, it pushes out 900+ watts any given day, all are certified with certificate, i never encountered one below 900 on cert, cea certified, for the l7, maybe the zx1500 kicker makes very hi quality amps, i used to have 3 12 inch l5 in kicker boxes with zx750 for each |
