Thread: HELP PLZ!!! |
Bronze Member Username: Doofdoof
Australia
Post Number: 39 Registered: Mar-07
| Posted on Saturday, March 31, 2007 - 11:12 pm: |
G'day guys i need help on how to wire an amp lol, 1st time so yea...so do you's hav ne internet sites or diagrams that could help me, id be very thankful... |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 1184 Registered: Jul-06
| Posted on Saturday, March 31, 2007 - 11:18 pm: |
Not sure exactly what you're asking, but you will likely find some good info here: www.bcae1.com |
Australia
Post Number: 40 Registered: Mar-07
| Posted on Saturday, March 31, 2007 - 11:29 pm: |
sry...just where to put the wires on the amp..like which wire goes where, type of thing...pretty much how to hook the hole thing up.. |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 717 Registered: Nov-04
| Posted on Sunday, April 01, 2007 - 01:29 am: |
Power wire(usually red) - to battery positive terminal; your amp has a connection labeled for this (+12V or similar) Ground wire (usually darker color) - to car chassis; somewhere where it's clean and you can make a solid connection. Remote wire - to your head unit's corresponding remote connection. |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11761 Registered: Dec-03
| Posted on Sunday, April 01, 2007 - 02:57 pm: |
RTFM |
