Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > ED Nine.1
Author Thread: ED Nine.1
Username: Smoke05
Tucson, Arizona
U.S.
Post Number: 232
i want buy that amp to power 1 fi Q (or maybe 1 Bl)
but it is on backorder... do you guys know when is going to be available or something... thanks
Username: 420alldaylong
Post Number: 1263
Not sure on that NINe.1 but check these out.
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3942
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4676
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5469
Username: Jkidder
Spring hill, Florida
Usa
Post Number: 409
ed nine is a better amp then all the ones joey mentioned by far it can put out around 1450 easy. its rated at 12.5V
Post Number: 1268
Around 1450 then boom
I've only seen and heard bad thing about ED NINe.1
Username: Oleg
Santa Monica, CA
Post Number: 716
Better by far? Don't think so. Those DEI and Orion are solid...no joke about it.
Username: Imalik
SD2.5, New Jersey
Ocean
Post Number: 198
Joey what bad things have you heard about the 9.1
Post Number: 1277
Mostly heating
Username: Smoke05
Tucson, Arizona
U.S.
Post Number: 235
thanks!!, then i may go with orion
i kinda liked the idea of having a warranty for 5 years
Username: Jkidder
Usa
Post Number: 413
any of those will power ur sub nnicely im just sayin i would get the ed nine over any of these new orion amp
Username: Smoke05
Tucson, Arizona
U.S.
Post Number: 236
lol ... so mixed reviews ...
so i think i will go with a budget one for now then... maybe a hifonics instead of the eD... or maybe a jbl... well thanks anyway
Username: Oleg
Santa Monica, CA
Post Number: 718
most JBLs are 2ohm stable, hifonics are overrated. Orion is really really nice...talking from experience.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4337
kicker kx 1200.1, memphis prd 1000.1, orion 1200d... many amps bro.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1650
the orions i have used/seen heat up much faster than NINe.1s. i own 4 NINe.1s and have never had a heating problem...dont really know where you guys got that one.
another great amp too look for on ebay is a crossfire 1000d, i love that amp. the kicker kx 1200.1 that juliob said is another good call.
Username: Smoke05
Tucson, Arizona
U.S.
Post Number: 239
does anyone know how this amp is rated? (under, fairly or overrated?)
Memphis 16-PRD1000.1
Username: Ctmike
Ct.
Post Number: 3727
that's memphis' lower line. still good and just slightly underrated from the one's i've seen.
Username: Imalik
SD2.5, New Jersey
Ocean
Post Number: 200
Hifonics are great budget amps, they do close to the rated power and they are 1 ohm stable...I have a BXI 1206D pushing 2 12 AQ 2.5 nice boom.
Username: Mmaudioconcepts
Murray, KY
Post Number: 118
are those powerbass amps any good
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > ED Nine.1 [ « Previous ] [ Next » ]
