Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Same amps with different birth sheets
Author Thread: Same amps with different birth sheets
Username: Mash4kash
Lafayette, LA
Post Number: 77
Lets say I get 2 Punch bd1001.1, 1 says 1280 watts the other says 1210 watts on the birthsheets,now i go ahead set the gains and everythang the same and put each on a s15L7 will 1 sub hit harder because the birthsheet shows it puts out 70 watts more than the other amp?
Username: Nd4spd18
Southeast PA
Post Number: 1177
It will work if you use a DMM to set the gains exactly the same on both.
Username: 420alldaylong
Post Number: 1262
Thats one of the reasons people run 1 big amp because of that. Get one Rockford T10001 and you will be set. T10001 underated power
Username: Mash4kash
Lafayette, LA
Post Number: 79
a 1000 nah I need at least a 1500 to 2500 amp punch 1500.1 usually got at least 1700 watts on birth sheet the kicker zx1500.1 too so its gon be a T20001 ZX1500.1 BD1500.1 or zx2500.1 all underrated
Username: Matt12490
California
Post Number: 2084
70 watts is not going to be noticable.. 500 would be hardly noticable (audibly)
Post Number: 1270
S.L.A.B.
Budget?
Username: Jkidder
Spring hill, Florida
Usa
Post Number: 411
yea u will not be able to hear any audible difference in 70 watts. i wouldnt worry about it. save u some money no need to replace
Username: Mash4kash
Lafayette, LA
Post Number: 88
I'm not on a budget when it comes to car audio if i hear it and i like it i'ma get it whether its a zx2500.1 t40001 or 10000 watt amp, I mean my parents ain't gave me sh!t but if i want something trus me i'm gonna get exactly that i already got 2 new s15L7's not really into competition EXCEPT at the light, taco bell, in the hood or anywhere sum fool talkn sh!t neway just tryna get the right top of the line amp for my solobarics
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4336
there won't be difference. 70w is nothing compared to 1k man.
Post Number: 1281
S.L.A.B.
If you get Rockford amps get the Power series they are way better amps than the punch amps.
Post Number: 1282
What ohm are the subs?
Username: Mash4kash
Lafayette, LA
Post Number: 94
you talkn bout the T 2006-2007 punch amps, nah I can't cuz they rate e at 1 ohm I got 2 2ohm dvc they only 2 or 4 ohm stable thats why i was gonna go with kicker zx or the punch bd series which are 2 ohm
Username: Mash4kash
Lafayette, LA
Post Number: 95
2 ohm dvc
Post Number: 1284
S.L.A.B.
Check this out
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=3
Username: Mash4kash
Lafayette, LA
Post Number: 96
yep 3 options for me 0.5, 2,o 8 ohm load
Post Number: 1286
Look know more two Sundown SAZ1500D stapped together to make a 2ohm. Kick azz amps $450each from Low-Hz.com
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16918
Username: Mash4kash
Lafayette, LA
Post Number: 98
O yea I needa know if using 2 punch 1000bd with bd sync cable strapped together how u set everything? cuz if get that and the cable off ebay i won't get any instructions and i'm go be like how da fukkk I put this together, u kno
Post Number: 1290
S.L.A.B.
How much are you paying for those RF 10001?
Username: Mash4kash
Lafayette, LA
Post Number: 100
200 each I'm tryna talk a dude into selling me a 1500.1bd for 300
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Same amps with different birth sheets [ « Previous ] [ Next » ]
