Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Hifonics or Orion?
Author Thread: Hifonics or Orion?
Username: Lowgan
Post Number: 22
Should i get the Hi-fonics XX-Thor or the orion HCCA-5000?
Username: 420alldaylong
Post Number: 1256
If these (spec) are right the Hifonics more power.
http://www.sonicelectronix.com/item_8426_Hifonics+XX-THOR.html
http://www.sonicelectronix.com/item_7562_Orion+HCCA-D5000.html
Username: Nd4spd18
Southeast PA
Post Number: 1171
It would be about equal since Hifonics power ratings are about 20% over.
I would say get whichever one is cheaper. They should be about equal in terms of quality also. The only difference I can see is the higher SNR on the Hifonics.
Username: Oleg
Santa Monica, CA
Post Number: 713
Friend has a hifonics and orion, not those exact models. Orion seems to run cooler and I generally prefer orion, it's a good brand to go with.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4335
"It would be about equal since Hifonics power ratings are about 20% over".
That's not true. Remember that hifonics brutus line is the only overrated. All XX models are accurately rated or underrated, and their quality is good.
Username: Jkidder
Spring hill, Florida
Usa
Post Number: 415
yuh the XX series r the good amps from hifonics. they dont heat up n' put out exactly wat they say.
Username: Imalik
SD2.5, New Jersey
Ocean
Post Number: 202
So true Julio...The Brutus amps are what they are great budget amps..a ton of people tend to think Hifonics only make the Brutus line, and say ALL Hifonics amp are overrated ,thats just not the truth.
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Hifonics or Orion? [ « Previous ] [ Next » ]
