Thread: Looking for a nice 4 channel amp... |
Silver Member Username: Jaguar600
Post Number: 127 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 01:22 am: |
I am trying to find a relatively inexpensive 4 channel amplfier, but still something that will get the job done a little better than a headunit will. I found the Pioneer GM-4300F. Is this a decent amp? |
Gold Member Username: 420alldaylong
Post Number: 1235 Registered: Sep-06
| Posted on Saturday, March 31, 2007 - 01:25 am: |
Not sure on that amp but how much do you want to spend on a amp. |
Post Number: 128 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 01:29 am: |
Well I found that amp for $100 shipped so somewhere around there would be great. |
Post Number: 1240 Registered: Sep-06
| Posted on Saturday, March 31, 2007 - 01:37 am: |
Little more than the other but better. http://www.sonicelectronix.com/item_3579_Kicker+KX200.4+.html |
Post Number: 130 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 01:42 am: |
hmm I was looking at that kicker too.. Any other suggestions? I saw some power acoustics for good prices but I dont think they are very good... Also its going onto a factory radio if that helps |
Post Number: 1242 Registered: Sep-06
| Posted on Saturday, March 31, 2007 - 02:02 am: |
Stay away from Power Acoustics VERY overated. http://www.millionbuy.com/powasa4004.html http://www.millionbuy.com/phgr504.html http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=5673 There all good but the kicker is the best out of those I listed. I hope this helps you out, |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 706 Registered: Nov-04
| Posted on Saturday, March 31, 2007 - 03:14 am: |
How much power do you need per channel? |
Silver Member Username: Riskyb
Post Number: 536 Registered: Feb-06
| Posted on Saturday, March 31, 2007 - 03:25 am: |
Diamond Audio D3400.4 about 160$ on ebay. Good audiophile quality and nice looking aesthetics. |
Post Number: 131 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 10:28 am: |
looking for only about 40+ watts rms per channel. Instead of putting a headunit in i am going to put in an amp. |
Post Number: 132 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 10:37 am: |
Between these 2 what do ya think... http://www.millionbuy.com/phgr504.html http://www.parkaveelectronics.com/product.asp?itemid=PIOGM4300F&l=Froogle I never really heard about phoenix gold. Would it be a better amp than the pioneer? ALso it doesnt have speaker level inputs so where do I get the adaptor to convert to racas? |
New member Username: Tibr6
Post Number: 2 Registered: Mar-07
| Posted on Saturday, March 31, 2007 - 12:17 pm: |
My 2 cents would be to upgrade the factory radio to a better aftermarket radio before you do anything else. Thats the best upgrade you can do. For amps I would use an Orion HP-4600 or the Kicker. |
Post Number: 133 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 12:23 pm: |
But I can get more power out of an amp rather than a new headunit and I dont need a new headunit the factory one is fine. Also if I take out the factory one I need to put in a $150 mounting kit to not lose the information center and I spend less putting a new amp in rather than a headunit and the mounting kit. |
Santa Monica,
CA
Post Number: 711 Registered: Nov-04
| Posted on Saturday, March 31, 2007 - 01:42 pm: |
I see what you're saying. You want something louder and cleaner and you don't want to spend a lot? I would take that diamond audio that Grant suggested. The kicker and orion are also nice. If those are too expensive, I'd take the PG over the pioneer. HU upgrade is something you'd want to do soon though. |
Post Number: 1250 Registered: Sep-06
| Posted on Saturday, March 31, 2007 - 02:17 pm: |
Out of those two get the PG. http://www.millionbuy.com/phgr504.html |
Post Number: 137 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 02:35 pm: |
Alright sounds good thanks alot |
New member Username: Luvbass
To,
Ca
United states
Post Number: 5 Registered: Apr-07
| Posted on Monday, April 02, 2007 - 01:33 am: |
kicker is way under rated, if it says 40 rms its more like 55 my zx750 is rated supposed to be 750 at 2 ohms, certified 932rms at 2 ohms, love kicker amps, some of the best on the market ive seen |
