Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > What is a good amp
Author Thread: What is a good amp
Username: Djhasanicesoundsystem
Vista, Ca
Usa
Post Number: 67
im looking for a new amp that i need to run 2 kicker compvr's dual 4ohm. i already have an alpine mrp m650 but people keep saying that my subs are being under powered. or could i just get another amp of the same thing and just run them 1 to 1
Username: Jeromebaker
Post Number: 103
ROckford's power series are all good.
Any monoblock amp by JL is good.
Hifonics amps are good and cheap.
It all depends on what you want to spend.
Username: Oleg
Santa Monica, CA
Post Number: 695
yeah, since you already have this amp, just get another one and it should be fine. the subs may be a bit overpowered then, hopefully they can take it. at 14.4V, the amp puts out 600W apparently. BTW how do you have the subs wired now? at 4ohms? amp is only 2ohm stable.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4326
memphis prd 1000.1
Username: Oleg
Santa Monica, CA
Post Number: 697
probably overkill with that memphis since he already has 1 alpine. You can get one more of that same alpine amp on ebay for under $200 and have more power, while operating at 2ohms.
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > What is a good amp [ « Previous ] [ Next » ]
