Thread: Hk4000d how do you achieve 17 volts? |
New member Username: Ttam
Post Number: 1 Registered: Mar-07
| Posted on Friday, March 30, 2007 - 12:44 am: |
???????????????????????????????????????????????? I got a 2000 caddy deville. i got a red top in line with my factory alt. and battery. i was getting 15plus volts in another car, now i'm showing 13 - 14.7 volts in this car. it keeps changing. anyway i was thinking of getting the hk4000d for a good price but don't want to waist my time if i can't get the right juice to it. any help will be appreciated. got a good deal on 2k - 4k watts let me know.mattprudhomme@yahoo.com |
Platinum Member Username: Rovin
My 1 12 Atom...
Post Number: 11088 Registered: Jul-05
| Posted on Friday, March 30, 2007 - 01:17 am: |
Thread: Hk4000d how do you achieve 17 volts? from what i read : by getting a custom built high output alternator which has a regulator which allows it do put out that much constant voltage ...... |
Silver Member Username: Skies
Courtenay,
British Colu...
Post Number: 485 Registered: Aug-05
| Posted on Friday, March 30, 2007 - 01:24 am: |
EA makes voltage regulators, contact Nate? Also, I assume you would need a new battery that would support 17V wouldnt you ? |
Courtenay,
British Colu...
Post Number: 486 Registered: Aug-05
| Posted on Friday, March 30, 2007 - 01:25 am: |
Sorry, Excessive Amperage |
Silver Member Username: Waterboy2289
Martinez,
Georgia
2 18 SX w/ ...
Post Number: 185 Registered: Jan-06
| Posted on Friday, March 30, 2007 - 09:58 am: |
If it is a daily driver system then STICK TO 14 VOLTS! If the system is competition based, then start asking about 17 volts. What subs are you trying to run? |
Bronze Member Username: Bumpndatrunk
Milwaukee,
WI
Post Number: 76 Registered: Mar-07
| Posted on Friday, March 30, 2007 - 01:51 pm: |
what do you mean when you say competition based |
Martinez,
Georgia
2 18 SX w/ ...
Post Number: 190 Registered: Jan-06
| Posted on Friday, March 30, 2007 - 03:10 pm: |
If he plans to use the system for competition only, not a daily driver. In that case he would be able to use 16 volt batts or what ever. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4325 Registered: Dec-05
| Posted on Friday, March 30, 2007 - 05:48 pm: |
17V= lot of money. |
