Thread: Problem here  |
Bronze Member Username: Theivan
Dawson Creek,
British Colu...
Post Number: 25 Registered: Mar-07
| Posted on Wednesday, March 28, 2007 - 01:26 am: |
k well i replaced the fuse my amp just blew (JL 500/1) and it was a 60 amp fuse same fuse same ratinga as my old one. but now my subs only stay at one volume and plus when theyre at low volume it sounds like static. any ideas on how to fix this or did i somehow f*uck my amp? :'( |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11730 Registered: Dec-03
| Posted on Wednesday, March 28, 2007 - 09:14 am: |
could be a wiring problem (bad ground, loose cable etc) otherwise, make sure the amplifier gains are set properly an not cranked all the way up if both of these check OK, your amp is damaged. |
Bronze Member Username: Bradddgeezy
Fort Wayne,
IN
Post Number: 12 Registered: Mar-07
| Posted on Wednesday, March 28, 2007 - 09:50 am: |
yeah i had a problem like that on my first amp. and it turned out that 2 of the channels were fried... good luck |
Dawson Creek,
British Colu...
Post Number: 29 Registered: Mar-07
| Posted on Wednesday, March 28, 2007 - 02:34 pm: |
k ill check the wiring and maybe use the other channel. if this doesnt work ill try using my old amp. hope i didnt fry my subs when this happened. ill post back later tonight or tomorrow to tell if i got it fixed. it might be a couple days ill have some pros take a look..... |
Dawson Creek,
British Colu...
Post Number: 30 Registered: Mar-07
| Posted on Thursday, March 29, 2007 - 12:24 am: |
yeah no luck, checked all my wiring the place i bought it from will have a look for me and might replace it for free.  |
