Thread: Double the power: looking for 600rms @ 1ohm |
Silver Member Username: Gavbo211
JL Audio 10w3v2,
IL
US
Post Number: 388 Registered: Jan-05
| Posted on Tuesday, March 27, 2007 - 06:07 pm: |
I just got my hands on another 10w3v2-D4, so now i have to find some more power. I thought about maybe just runnin them both off my Phoenix Gold X400.1 (which is what i'm using to run the one i have now) but even with two subs, cutting the power in half i wouldn't expect much of a gain. So, i'm amp shopping. I need anywhere from 600-800wrms at 1ohm. preferrably for under $150, and definatley under $200. ebay is good too. I want to get a PG X600.1 (i looooooove my 400.1) but they are kinda pricey and hard to find. so any thoughts? |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 667 Registered: Nov-04
| Posted on Tuesday, March 27, 2007 - 09:40 pm: |
only reasonable one i can think of is hifonics bxi606 |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4314 Registered: Dec-05
| Posted on Tuesday, March 27, 2007 - 11:29 pm: |
PA a1000db or lanzar vibe 1200d brand new |
Gold Member Username: 420alldaylong
Post Number: 1193 Registered: Sep-06
| Posted on Tuesday, March 27, 2007 - 11:33 pm: |
Gavin Try this out http://www.millionbuy.com/powasa10001d.html |
Santa Monica,
CA
Post Number: 669 Registered: Nov-04
| Posted on Tuesday, March 27, 2007 - 11:59 pm: |
How are those powerbass amps? Do they put out rated power? How good's the build quality? |
Post Number: 1195 Registered: Sep-06
| Posted on Wednesday, March 28, 2007 - 12:14 am: |
I would say there quality is like Brutus amps %20-%25 overated. Thats my opinion |
JL Audio 10w3v2,
IL
US
Post Number: 389 Registered: Jan-05
| Posted on Wednesday, March 28, 2007 - 01:32 am: |
hmm.. all do-able amps, but it seems like we are lacking an overall quality factor.. for the price i would take those, but i was thinking more along the lines of finding an old Orion 600D on ebay for like $175 or around there. any opinion on that match up or does anyone have anything they think would be better than that? |
Post Number: 1197 Registered: Sep-06
| Posted on Wednesday, March 28, 2007 - 03:52 am: |
Gavin Check this out http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13470 |
Santa Monica,
CA
Post Number: 672 Registered: Nov-04
| Posted on Wednesday, March 28, 2007 - 04:17 am: |
Maybe 2 kicker zx300.1 - it's over $200 shipped on eBay though. I suppose I'd try the powerbass one then. |
Post Number: 4317 Registered: Dec-05
| Posted on Wednesday, March 28, 2007 - 04:51 pm: |
i don't think powerbass ASA is overrated. Some facts: 1- there is a pic where the ampp has 3x40A fuses. That means it should put 1000w rms at least. 2-In specs, they say 3x30A fuses. I've seen a lot of 1000w rms amp using 3x30a fuses so it should be right there. The one i know doesn't puts the power is hifonics bxi1206d. A 80a fuse might put 1000w rms, but it takes good efficiency to achieve that power, and i dont think hifonics brutus is the best when it comes to efficiency |
JL Audio 10w3v2,
IL
US
Post Number: 391 Registered: Jan-05
| Posted on Wednesday, March 28, 2007 - 09:40 pm: |
juliob - i agree about the hifonics, i was trying to not get to expensive and stay away from them at the same time.. lol. honestly the more i look at that powerbass the more i like it.. the clean design.. and the specs are really good for the price. i think that might be my choice... thanks for all your help guys. |
Silver Member Username: Renegadesrun
Lafayette,
IN
US
Post Number: 661 Registered: Oct-04
| Posted on Thursday, March 29, 2007 - 01:22 am: |
Memphis MC500 (245) Memphis PR 1.500 (210) US Amps XT800.2 (145) Plus ship. |
Santa Monica,
CA
Post Number: 674 Registered: Nov-04
| Posted on Thursday, March 29, 2007 - 01:24 am: |
the amp does look clean. if you're on a budget, unfortunately, it's hard to get power and build quality in one. |
Post Number: 1207 Registered: Sep-06
| Posted on Thursday, March 29, 2007 - 01:41 am: |
I agree |
Lafayette,
IN
US
Post Number: 663 Registered: Oct-04
| Posted on Thursday, March 29, 2007 - 02:08 am: |
His only option, with those parameters, is used, or refurbed. |
JL Audio 10w3v2,
IL
US
Post Number: 400 Registered: Jan-05
| Posted on Thursday, March 29, 2007 - 03:30 am: |
trust me, i know it's hard to get those two in one. i've had budget systems before, and i did it right last time, but now of course i need more. i'm thinkin maybe i'll just let the other w3v2 sit while i gather up some cash for a really nice amp. although i'm not satisfied with what i've got anymore (of course).. i guess i can wait it out though lol. |
Santa Monica,
CA
Post Number: 678 Registered: Nov-04
| Posted on Thursday, March 29, 2007 - 03:58 am: |
yeah, stick with what you've got now and save a bit more. else you'll always find yourself spending more without really getting more. |
Post Number: 1209 Registered: Sep-06
| Posted on Thursday, March 29, 2007 - 05:28 am: |
http://forum.ecoustics.com/bbs/messages/4/341298.html |
Silver Member Username: Fiber
15 Wangers PBX
Post Number: 297 Registered: Mar-06
| Posted on Thursday, March 29, 2007 - 04:42 pm: |
Powerbase put out what they say I had the pb 2000.1, and I got it benched at 2004 watts at 1 ohm |
