Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Whats my best amp?
Author Thread: Whats my best amp?
Username: Bigman3889
Post Number: 69
i got 6 Pioneer TS-W306C subs
http://www.sonicelectronix.com/item_5292_Pioneer+TS-W306C.html
...im looking for an amp to match these subs...6 subs...400 RMS a piece... 2400RMS total... running 2 amps to power all 6 subs is not a problem.. im 18 years old making about 100$ a week lol thats my budget... whats my best value..around 400ish?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4307
two hifonics bxi 1606d
Post Number: 71
how would u wire 6 subs with a single voicecoil to it...i can get either 4 ohms or 2 ohms...which ever will wire it to get my fullest from my subs
Username: Nd4spd18
Southeast PA
Post Number: 1138
If using 2 amps, you will need to wire 3 subs to each amp in parallel, for a 1.33 ohm load to each amp.
So choose amps that are 1 ohm stable, and produce a little more power than you actually need, since you will be running a little higher impedence.
Username: Imalik
SD2.5, New Jersey
Ocean
Post Number: 192
Take a look at this amp...Rob is running 6 10's with this amp,its in your price range.I had the sames subs, Im sure the amp will do a good job. The site is real good.http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16370
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Whats my best amp? [ « Previous ] [ Next » ]
