Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Which Amp is better?
Author Thread: Which Amp is better?
Username: Livingloudl7
Post Number: 37
Hifonics Bxi 2000D or Lanzar Opti 2000D.. i've heard some pretty good stuff about the opti line for lanzar but would it be better than hifonics?
Username: Imalik
SD2.5, New Jersey
Ocean
Post Number: 189
IMO the Hifonics, Im sure some ppl will say the Lanzar.
Username: Skies
Courtenay, British Colu...
Post Number: 445
I would go Hifonics.
Mostly for reputation's sake. Lanzar has worse reputation than Hifonics.
Username: Nd4spd18
Southeast PA
Post Number: 1118
Quality is about equal there, they are both good budget amps. Get whichever costs less.
Username: Newkid77
Post Number: 22
if your looking for cheap lanzar's go to
http://www.allaudioexpo.com/nav/listing.asp
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4310
i'd buy lanzar optidrive instead of hifonics. Lanzar puts 1600w rms at 1 ohm 14.4V and 1962w rms at 0.5 ohms 14.4V
Username: Bigman3889
Post Number: 70
I think im gonna deff go with the hifonics BXi 2006D..it was actually what i wanted to get in the first place just wanted opinions...but now how about wiring 6 subs to it...single voicecoil..it can be either 2 ohm or 4 ohm subs...cause that will confuse me lol
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Which Amp is better? [ « Previous ] [ Next » ]
