Thread: Will it be louder? |
New member Username: Christogq
Post Number: 4 Registered: Mar-07
| Posted on Monday, March 26, 2007 - 01:00 pm: |
I have a Planet Audio 1250 and two 12" Quantum Audio woofers. The woofers are 1500 watts max each. My amp is only 1200 watts. I have to turn the amp all the way up to really make any kind of noise. Will it be louder if I go with some woofers that require less power? |
Gold Member Username: Ctmike
Ct.
Post Number: 3700 Registered: Feb-06
| Posted on Monday, March 26, 2007 - 01:07 pm: |
first, post the rms of the subs. peak means nothing. second, what id the rms of the amp. and when you say "turn the amp all the way up" do you mean your using the gain as a volume? if so that is really bad and isn't what it's for. |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 1109 Registered: Jul-06
| Posted on Monday, March 26, 2007 - 02:46 pm: |
Set the gain properly, it is not a volume control! |
Post Number: 5 Registered: Mar-07
| Posted on Monday, March 26, 2007 - 06:36 pm: |
I don't know how to find the RMS on the amp cause the only listings I see are the max at 1ohm and that's what I have it wired to. I use my gain as a volume control, like how much power it's putting out to the subs. Pleas tell the young grasshopper what I am to do. |
Ct.
Post Number: 3707 Registered: Feb-06
| Posted on Monday, March 26, 2007 - 06:44 pm: |
here's the only specs i've found: Max Power (2 Ohms) 1000W X 1 Max Power (1 Ohm) 1250W X 1 RMS Power (4 Ohms) 450W X 1 RMS Power (2 Ohms) 700W X1 Signal-to-Noise Ratio Frequency Response Dimensions: 102dB 20Hz-250Hz 6-1/2”W x 2”H x 18-1/4”L you might have to call them or search around the web for what it does at 1ohm. but again, posting the rms of the subs would help. and never use the gain as a volume knob, set it to match the preout voltage of your hu (head unit) and leave it. |
Post Number: 6 Registered: Mar-07
| Posted on Monday, March 26, 2007 - 06:50 pm: |
Oh sorry about that. The subs are 750 watts rms each. So let's say my amp rms is 700 watts, then wouldn't I get louder and cleaner and deeper bass with some woofers that require and handle less power? How do I set my gain to match the preout voltage? Man I've been messing with car stereo stuff for like 6 years and I've never had this much trouble. Thanks guys. |
