Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!...
Author Thread: HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Clark09_5hotmailcom
McCook, Nebraska
ok so i just hooked up my subs and amp and if i turn the bass up any louder than ten notches on my stock head unit it makes my subs cut out and about 5 seconds later they start bumpin again which if i turn the bass down than it wont do that. It should be hitting a lot harder than it is. any suggestions?
Username: Glasswolf
Wisteria, Lane
Post Number: 11702
your gain on the amp is probably set way too high.
don't turn it any higher than 1/4 of the way up, and see it that stops.
the amplifier is going into protection from clipping.
Username: Glasswolf
Wisteria, Lane
Post Number: 11703
what amp and what sub(s) are you using by the way?
Username: Djbeanpole
Naptown, Indiana
Post Number: 355
Reposts are delicious
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!... [ « Previous ] [ Next » ]
