Thread: 2 different amps?? |
Silver Member Username: Bies08
Wheaton,
Kansas
Post Number: 126 Registered: Dec-05
| Posted on Monday, March 26, 2007 - 12:08 am: |
ok soo im getting a new set up. im going ot have one W6 that im going to power with an Audiobahn A1300HCT. Then im planning on haveing another sub (you guys woudlnt know what brand it is if i told you anyways) its 300 RMS tho. I plan on powering that with and Alpine MRD-M605. how do i get the power wire and all that to both amps? |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 1105 Registered: Jul-06
| Posted on Monday, March 26, 2007 - 12:12 am: |
Don't mix different types of subs, it will cause cancellation. |
Wheaton,
Kansas
Post Number: 127 Registered: Dec-05
| Posted on Monday, March 26, 2007 - 12:14 am: |
cancellation???what? |
Gold Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 1609 Registered: Sep-04
| Posted on Monday, March 26, 2007 - 12:16 am: |
It'll just sound bad. -Fishy |
Wheaton,
Kansas
Post Number: 129 Registered: Dec-05
| Posted on Monday, March 26, 2007 - 12:19 am: |
Silver Member Username: Skies
Courtenay,
British Colu...
Post Number: 441 Registered: Aug-05
| Posted on Monday, March 26, 2007 - 12:21 am: |
The W6 on its own will sound good. Just make sure its in a nice box. As for power, get a Distribution Block. Knukonceptz makes nice ones. |
Wheaton,
Kansas
Post Number: 130 Registered: Dec-05
| Posted on Monday, March 26, 2007 - 12:29 am: |
well how would i do it just in case. after awhile im getting 2 more W6's and im going to power the 2 w6's with the audiobahn then the third one with the alpine. |
Wheaton,
Kansas
Post Number: 132 Registered: Dec-05
| Posted on Monday, March 26, 2007 - 12:36 am: |
whats a distribution block do??? |
Courtenay,
British Colu...
Post Number: 442 Registered: Aug-05
| Posted on Monday, March 26, 2007 - 12:45 am: |
Power wire goes from (Battery+) to Distribution block. It basically effectively splits 1 wire into two. Use ~2Gauge from battery to distribution block, then 4 gauge from distribution block to amps. |
