Thread: Testing a NEW amp with a multimeter |
Bronze Member Username: Paulmasoner
Honolulu,
Hawaii
Usa
Post Number: 50 Registered: Oct-06
| Posted on Sunday, March 25, 2007 - 05:14 pm: |
hey guys i am a little new to using a MM. can someone give me a brief idea how i can test is i have signal going IN and coming OUT of my amp? heres my situation. 06 RX-8, kicker zx400.1, kappa perfect 12" dVQ, david navone 2 channel line converter. i tapped into the inputs to the factory Bose amp i.e. out of the head unit with the line converter, and got nothing, so i tried tapping in AFTER the bose amp, nothing. i checked and rechecked everything. then i just took the LOC out, and used the high level inputs on the amp... from before and after the factory bose amp, still nothing. far as i can tell the amp is powered right.. not going into SORT protect mode, grounded well etc... |
Honolulu,
Hawaii
Usa
Post Number: 51 Registered: Oct-06
| Posted on Sunday, March 25, 2007 - 09:34 pm: |
figured it out, no worries. i had the sub wired for 8 ohm load, not 2 |
