Thread: What frequency test track did u guys set ur gains at? |
Bronze Member Username: Oaktowncrazyd
East Oakland,
CA
Post Number: 43 Registered: May-06
| Posted on Sunday, March 25, 2007 - 05:09 pm: |
topic^^^^^ |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11690 Registered: Dec-03
| Posted on Monday, March 26, 2007 - 08:55 am: |
I use a full spectrum pink noise generator for that. even power output @ 20-20KHz That way I can see the curve on an RTA, too. |
Bronze Member Username: Dj_007
Carlisle,
KY
US
Post Number: 66 Registered: Dec-06
| Posted on Monday, March 26, 2007 - 03:40 pm: |
for setting the gain just on subs i used a calculator i found on the internet.. i will get a link ... but anyways you put in the fuse rating on it and how much power it is supposed to put out and it will give you a certain voltage it should put out at 60hz to keep from clipping.. then you hook up a multi meter to the terminals play a 60hz tone and adjust the gain to the voltage output that is recomended |
