Thread: Looking for a 1000 rms per channel |
Bronze Member Username: Nascarfan
Tallahassee,
Florida
Post Number: 32 Registered: Mar-07
| Posted on Sunday, March 25, 2007 - 01:30 am: |
Want to buy a 1000 rms per channel amp, so basically I need a 2000 watt amp. I want to run 1000rms to each 12" sub. Thanks Chris |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 2281 Registered: Mar-06
| Posted on Sunday, March 25, 2007 - 01:37 am: |
Heres a break down on some decent amps. Some are junk, some are great. But its a starting point. Whats your budget and subs voice coil config? http://www.lightav.com/car/amps/poweramps.html |
Bronze Member Username: Mash4kash
Lafayette,
LA
Post Number: 74 Registered: Feb-06
| Posted on Sunday, March 25, 2007 - 01:42 am: |
at what ohm |
Platinum Member Username: Rovin
My 1 12 Atom...
Post Number: 11035 Registered: Jul-05
| Posted on Sunday, March 25, 2007 - 01:56 am: |
sub model no ? ...... |
Silver Member Username: Killswitchjd
Post Number: 350 Registered: Apr-06
| Posted on Wednesday, March 28, 2007 - 03:48 pm: |
figure he wants a 2 channel 1000x2 rms at 1 ohm or 4 ohms |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4315 Registered: Dec-05
| Posted on Wednesday, March 28, 2007 - 04:44 pm: |
post subs, RMS and voice coil config Tell us a budget Do you have a good charging system? |
Tallahassee,
Florida
Post Number: 43 Registered: Mar-07
| Posted on Friday, March 30, 2007 - 09:51 pm: |
Sorry I was away, I have Alpine Type R's 12" dual voice @4 ohms, max watt rating is 1500 with a 500 RMS, I would like to have enough power to run both subs in sealed box, and have plenty of power for backu-up, any suggestions or any for sale at a reasonable price say under 350.00 bux? Thanks Chris |
Silver Member Username: Freezeman_7
Lindsay,
Oklahoma
U.S.A
Post Number: 831 Registered: May-06
| Posted on Friday, March 30, 2007 - 10:02 pm: |
man i mono sub would be cheaper than a 1000x2 amp. get a mono amp. cheaper and better. jus my .02tho |
Tallahassee,
Florida
Post Number: 44 Registered: Mar-07
| Posted on Friday, March 30, 2007 - 10:05 pm: |
Yea mono was what I was thinking as well, I would like to get at least 800rms to each sub at either 4ohm or 2ohm, or 1ohm. |
Lindsay,
Oklahoma
U.S.A
Post Number: 833 Registered: May-06
| Posted on Friday, March 30, 2007 - 10:07 pm: |
no, if u get a 2000wrms mono amp. u will get 1000wrms to each sub. it will distribute the power evenly. |
Tallahassee,
Florida
Post Number: 45 Registered: Mar-07
| Posted on Friday, March 30, 2007 - 10:35 pm: |
I thought about the Hifonics Brutus or maybe the CADENCE ZRS10, they have decent prices but are they reliable for every day usage. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=015&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D250098636133%26%26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=015&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D250095266472%26%26 |
Gold Member Username: 420alldaylong
Post Number: 1225 Registered: Sep-06
| Posted on Friday, March 30, 2007 - 10:57 pm: |
This amp will bang the s h i t out of those subs. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16368 |
Bronze Member Username: Josh1005
Norfolk,
VA
U.S.A
| Posted on Friday, March 30, 2007 - 11:48 pm: |
i have a JL 1000/1 and it powers my 3 12" JLs at 2ohms and it sounds real good. just a thought on the amp, i have no complaints it has alot of raw power |
My 1 12 Atom...
Post Number: 11103 Registered: Jul-05
| Posted on Saturday, March 31, 2007 - 12:42 am: |
dude ignore max rating - look @ wrms so its 500wrms each x 2 though those subs can handle 600wrms cool look for an amp that does 1200wrms @ 1ohm - go ebay ...... |
Silver Member Username: Skies
Courtenay,
British Colu...
Post Number: 499 Registered: Aug-05
| Posted on Saturday, March 31, 2007 - 03:09 am: |
eD NINe.1. $365 Shipped to your door. http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=44 |
Tallahassee,
Florida
Post Number: 46 Registered: Mar-07
| Posted on Saturday, March 31, 2007 - 07:03 am: |
Thanks guys, looks like i need to do some searching |
Tallahassee,
Florida
Post Number: 47 Registered: Mar-07
| Posted on Saturday, March 31, 2007 - 08:38 pm: |
Hi what do you think about this amp here AUDIOBAHN A1500HCT HIGH CURRENT MONO AMP 2000W? |
Tallahassee,
Florida
Post Number: 48 Registered: Mar-07
| Posted on Saturday, March 31, 2007 - 09:39 pm: |
Nevermind...I changed my mind on that amp |
Gold Member Username: Arande2
Extreme SQ FTW
Post Number: 2206 Registered: Dec-06
| Posted on Saturday, March 31, 2007 - 10:11 pm: |
Just buy a Rockford Fosgate T15kw and be done with it. |
Tallahassee,
Florida
Post Number: 49 Registered: Mar-07
| Posted on Sunday, April 01, 2007 - 05:12 am: |
lol.my credit line doesnt go that high :-) |
Bronze Member Username: Bholt30
Union,
Kentucky
United States
Post Number: 16 Registered: Mar-07
| Posted on Monday, April 02, 2007 - 12:34 am: |
try a sundown saz-1500D |
