Thread: Which sub!!! |
Bronze Member Username: Sexybrenty
Post Number: 13 Registered: Mar-07
| Posted on Friday, March 23, 2007 - 11:02 pm: |
= i found out my rockford fosgate 450.2 amp has this: RMS Power Output: 4 Ohms: 100 watts x 2 chan. 2 Ohms: 225 watts x 2 chan. 4 Ohms Bridged: 450 watts x 1 chan. what would be the best sub for it and what should i do with it? |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 11921 Registered: Jul-05
| Posted on Friday, March 23, 2007 - 11:15 pm: |
budget |
Post Number: 14 Registered: Mar-07
| Posted on Friday, March 23, 2007 - 11:18 pm: |
budget for sub would be about 200 but owuld prefer just one twelve inch or maybe two tens |
Huntsville,
Alabama
U.S.
Post Number: 11923 Registered: Jul-05
| Posted on Friday, March 23, 2007 - 11:21 pm: |
and the overall goal of ur setup??SPL??SQL??SQ?? |
Post Number: 15 Registered: Mar-07
| Posted on Friday, March 23, 2007 - 11:24 pm: |
lol im sorry im a total newb and dont know what any of that means. Im basically looking for a sub that would work with that amp to give me good osund quality but when turned up with the gain it will also bump pretty hard, its going on a small extended cab of a truck |
Gold Member Username: Ctmike
Ct.
Post Number: 3686 Registered: Feb-06
| Posted on Friday, March 23, 2007 - 11:43 pm: |
"turned up with the gain" gain is not a volume knob. |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 1064 Registered: Jul-06
| Posted on Friday, March 23, 2007 - 11:52 pm: |
^^^^^^ X2 |
Post Number: 16 Registered: Mar-07
| Posted on Friday, March 23, 2007 - 11:59 pm: |
i understand that, i meant to say when the gain is up itll hit hard when i need it to |
Huntsville,
Alabama
U.S.
Post Number: 11924 Registered: Jul-05
| Posted on Saturday, March 24, 2007 - 12:03 am: |
ur gain shuld be set to match ur Hu's preout voltage.. |
Post Number: 17 Registered: Mar-07
| Posted on Saturday, March 24, 2007 - 12:07 am: |
ok im sorry for the confusion to everyone and on my own part, i meant to say that when need be if i need to turn up the power on either the bass knob or watever than itll hit hard |
Bronze Member Username: Big_edge_head
Post Number: 22 Registered: Mar-07
| Posted on Saturday, March 24, 2007 - 11:05 am: |
dont even use the bass knob. just turn the volume up. it does the same thing. u can clip the amp with bass boost |
Gold Member Username: 420alldaylong
Post Number: 1165 Registered: Sep-06
| Posted on Saturday, March 24, 2007 - 02:37 pm: |
brent watters Cheap and good you can't beat the price. http://www.sonicelectronix.com/item_3406_Kicker+05CVR122.html |
Post Number: 1166 Registered: Sep-06
| Posted on Saturday, March 24, 2007 - 02:40 pm: |
brent watters Wire it to a 4ohm. http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=2o hm_dvc&x=136&y=6 |
Post Number: 19 Registered: Mar-07
| Posted on Saturday, March 24, 2007 - 03:06 pm: |
so if i bridge it it should be fine? |
Post Number: 20 Registered: Mar-07
| Posted on Monday, March 26, 2007 - 10:35 pm: |
joey does that mean id have to bridge it or just one channel? |
Post Number: 1179 Registered: Sep-06
| Posted on Monday, March 26, 2007 - 10:48 pm: |
When you bridge it it will be one channel 450x1 4ohm bridged |
Post Number: 21 Registered: Mar-07
| Posted on Monday, March 26, 2007 - 11:56 pm: |
ok sounds good, ill be sure to pick it up and bridge it, thx joey |
Huntsville,
Alabama
U.S.
Post Number: 11959 Registered: Jul-05
| Posted on Tuesday, March 27, 2007 - 02:58 am: |
whoa..hold on...do u use ebay?? |
